Gents,
this is a build for tabs with 3G
– stock recovery 4.4.0
– kernel #489, kernel #537 [v1.3]
– 4 GB internal storage
– Dateimanager HD (Root)
– Nova Launcher
Hints:
...use Nova launcher and set animation/scroll to "faster than light" and
...enable Entropy Fixer with value 256
Build will also work on:
(just change the kernel and resource in folder rockdev/Images)
Pipo P4 3G: kernel #613 (set dpi=240 in build.prop)
Pipo P9 3G: kernel #130 (set dpi=240 in build.prop)
– Oma -
2013/04/16
Hello Oma, I need your aiuto..sul my pipo p1 I tried to flash the 1.3 version of the kernel and replacing pipo p4 resource with those of p1
I opened the Android tool, press switch, power off tab and properly recognized, tap on lower format and then run
but the process has failed!
Now I can not start it, is not recognized by Android tool ("No device found"), I tried with vol + and power button but is not recognized
The following users say thank you to Enr1988 for this useful post:
clindoeil
Don't do that. In resource.img is the database (dtb) of the 3.10.0 kernel. So mixing these things up will most likely end in a not booting kernel. Try Power and Vol - to do a reset.
Enr1988Per aspera ad astra, we rock the Tablets !
With usb connected.
2013/04/16
Unbrick using another pc with Windows 7
Go into loader mode by press and hold power an vol up..and flash twice the rom..because the 1st one the tab not boot..
My pipo p1 it's brand new(1 day) but when i try to do Antutu benchmark on the cpu bench the tab shutdown itself..this behavior  continue on Asphalt 8 for example..after only one race tab shutdown... i can feel hot in the back cover near Camera. What i can do? Try another de?
Or it's simple hw fault and i can try to have a replace? Thx Oma
Then you had an issue with the usb driver. Here is a Driver Assistant. It supports also win8 but not win 8.1. Make sure the file is in c:. Unistall driver first (to make sure the tab is not connected to a rk31 driver) then install.
The fault is most likely a hardware problem. The SoC gets instable when touching 1.6 GHz. Chinese production quality. What was the firmware/kernel coming with the tab?
2013/04/16
With cpu clocked at 1.4 ghz with trickstermod i can perform Antutu v5 and Antutu x with almost the same result 37K
Asphalt 8 run ok for many race without issue/shutdown.
I think that the fw coming on tablet out of box ke dated 260614...but i'm hot sure about that because flash your latest stock pipo p1 rom 19 august
Yeah, limit to 1.4 GHz is a known workaround without having any lack in day to day performance. But hard to understand for a SoC that is specified @ 1,8 GHz. It is up to you to make usage of your warranty or not.
2013/04/16
Seem that the limit of my CPU go up to 1.5ghz...no freeze or shutdown like on the first day of use
After that a quick questions: why alla the cores of CPU are online at same time at all frequencies? IT is a normal behaviour of rk3288 ?
What about a future development of cm11 or omni for pipo p1?
THX for all your great work
SeattletruthPer aspera ad astra, we rock the Tablets !
Currently Online: andikafox
58 Guest(s)
Devices in use: Desktop (51), Phone (7), Tablet (1)
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
THEDRACk
