[ ROM ] Pipo P1 3G 4.4.4 custom root firmware (2014/09/18)
Multi-Windows build for tabs with 3G.
Thanks Received: 1383
2014/09/19 - 16:08
Gents,
this is a build for tabs with 3G ;-)
 P1 by Oma build v1.2
 kernel #537 (change the kernel and resource in folder rockdev/Images before flash)
– stock recovery 4.4.0
– kernel #489
– 4 GB internal storage
– Dateimanager HD (Root)
– Nova Launcher
Hints:
– to prettify the build use
Xposed Framework > Starter Pack
Build will also work on:
(just change the kernel and resource in folder rockdev/Images)
Pipo P4 3G: kernel #640, kernel #665 (set dpi=240 in build.prop)
Pipo P9 3G: kernel #158, kernel #192 (set dpi=240 in build.prop)
– Oma –
v1.2_01.jpgImage Enlarger
ssingaram, PrEzi
ssingaram
2014/10/03 - 10:07
Hi Oma,
There is a bug with this kernel on the flashlight.  It is always on.
Best Regards
Suresh
2014/10/03 - 10:17
Here is an older kernel #483: http://crewrktablets.arctablet.com/?wpfb_dl=2023
ssingaram
2014/10/03 - 12:05
Thanks Oma.  Tried to reflash but still have the same problem with the old kernel for this ROM.  Any suggestions how to fix this problem.
Thank you.
Best Regards
Suresh
ssingaram
2014/10/03 - 15:48
Thanks man.  The last one works, no more issues with the flashlight anymore.
Thank you.
Best Regards
Suresh
PrEzi
Forum Posts: 57
2014/11/04 - 18:36
Hi OMA,
just to let you know that the new 1.3 is nice and I don't have problems with flashlight always on. I am also glad that you are using the new AndroidTool which seems to work a tad better in Windows 8.x (the old 1.5 didn't recognized the Odys Iron when I wanted to flash it, needed to do a "frankenbuild" by using AndroidTool from Riley's ROM with your ROM image and parameters, fortunately all went well ;-) ).
I wonder -- in the description it states that the ROM Version is 4.4.4, but in the settings it states "4.4.2" ?
Currently Online: firmwarefile
66 Guest(s)
Devices in use: Desktop (51), Phone (15), Tablet (1)
firmwarefile
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
