[ RK3288 ROM ] iFive Mini 4 Android 4.4.4 custom root firmware (2014/10/10)
gaetanolip
Forum Posts: 28
2014/10/14 - 17:53
Yepp, confirm the tests are done on a Teclast P90HD. However, similar hardware with 2k screen.
i know is similar hardware, but emmc and ram may have different performance. someone can test with ifive?
sinuhedl
Mexico
Forum Posts: 16
2014/10/14 - 22:41
I'd tested the videos bbb and sintel an booth worked fine on the mini 4, look great, vivid and fluent.
* 4096px × 1720px "sintel-1080-cfg02.mkv"
* 3840px × 2160px "bbb-3840x2160-cfg02.mkv"
Did antutu benchmark scored 33.6k with out tweaks or trick to improve it.
Did 3d marck bechmark scored 11k for ultimate and 7k for extreme test.
The eMMC test was passed with 25mb/s.
On the other hand since the previous fw a had a issue with the battery management, after the mini4 has charged complete using the wall charger, the system say it has only 1% of battery, which i have confirmed it not cause if i leave it working i does not power off, but i i leave it will shut down cause of the bad data.
Hope you could help me with it.
gaetanolip
Forum Posts: 28
2014/10/14 - 23:17
sinuhedl said
Thanks very much
dn15
2014/10/15 - 05:23
Hai, I'm new user ifive mini 4
I already update to this custom rom 4.4.4 from oma . My antutu score just 33.3 k, is it good ?
Sometimes when i test with antutu v5.1 , error occured, that antutu stop working
i want to download xposed installer 2.6.1 from this link http://repo.xposed.info/module/de.robv.android.xposed.installer . is it compatible with ifive mini 4 ?
Thanks Received: 1375
2014/10/15 - 07:08
When the rk32boards came up we were on Antutu 4.5.x. With this version you got scores around 40 k.
You will see such scores in the advertisings and I prefer to run this version to make it comparable (for me).
Antutu 5.x scoring is different, I don't know why. So, to answer your question: yes, around 33 k is good.
Xposed Framework is compatible. In post #1 is a link to a starter pack, which contains also the Exposed installer and a few useful modules.
Hint: do not use modules which customize the lockscreen. Due to the ifive customizing (weather widget) the build high likely crashes.
sxk309
2014/10/17 - 08:34
Hi Oma
Just curious how you make the volume up control on the navigation bar?
See pic in circle. Since Mini4 has no physical volume bottom. This could be useful for us Wink
Untitled.pngImage Enlarger
2014/10/17 - 17:22
Set this parameter in build.prop to true.
ro.rk.systembar.voiceicon=false
v1.1_22.pngImage Enlarger
sxk309
2014/10/18 - 00:58
Thank Oma
Work like a charm!!Laugh
sinuhedl
Mexico
Forum Posts: 16
2014/10/20 - 02:53
@Oma
I tried this but i i did something wrong after reboot the mini4 doesn't start complete, y does pass the oma's splash but then the screen it's on but just black, the power button makes tablet vibrate un patrons until if finally just stop :s.
Any idea of roll back ?
In case a new firmware flash, this is not posible from a Mac does it ? The tools are all Windows :(
Thanks !
2014/10/20 - 07:08
Use a Win7 PC and re-flash system.img (tick parameter and system).
sinuhedl
sinuhedl
Mexico
Forum Posts: 16
2014/10/20 - 18:51
Great !
I just work the system flashing, then apply the changes to the build.prop and worked too :)
As i didn't have any PC to use, i used a Windows 8.1 Virtual Machine in vmware fusion over Mac, i can tell you now its save to use it to flash without any problems and to install drivers and to the flashing progress.
Thanks !
The following users say thank you to sinuhedl for this useful post:
hro4649
2014/10/22 - 02:05
Thanks oma!
I tested this firmware from last week.
It is very stable.
Connection of Wifi does not have a problem, either.
2014/10/22 - 19:42
Thank you guys for feedback!
sinuhedl
Mexico
Forum Posts: 16
2014/10/28 - 18:07
Hi guys
@Oma
Is it posible to install custom recovery on this tablet ?
Cheers
82 Guest(s)
Devices in use: Desktop (75), Phone (7)
Falconfr
marreroivan
kelomonaco14
kelomonaco
jerrie
aless007
Members: 262104
