[ RK3288 ROM ] iFive Mini 4 Android 4.4.4 custom root firmware (2014/10/10)
Thanks Received: 1385
2014/10/10 - 21:28
Gents,
KTU84Q has landed on iFive Mini4 ;-)
Build is based on stock v2.0.2 dated 08. Oct 2014 and kernel #14 preempt 28. Sep 2014.
Mini4 by Oma build v1.1
– stock recovery 4.4.0
– kernel #14
– 4 GB internal storage
– init.d support
– Dateimanager HD (Root)
– Nova Launcher
new: TWRP and CWM
Hints:
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
v1.1_03.pngImage Enlarger
 v1.1_04.jpgImage Enlarger
 v1.1_02.jpgImage Enlarger
 v1.1_05a.pngImage Enlarger
 v1.1_08.jpgImage Enlarger
 v1.1_09a.pngImage Enlarger
 v1.1_07a.jpgImage Enlarger
 v1.1_06.pngImage Enlarger
MiGHT., panzol, lausarus, sinuhedl, a466604151, slavan
sinuhedl
Mexico
Forum Posts: 16
2014/10/11 - 01:27
Hi..
Already updated :)
The touch issues appears to have ben fixed totally !
Scroll line for brightness fixed !
Strange brightness after unlocking the tablet fixed .. (this one i thin i was the only one to have it)
Nice speed and overall stable wifi!
I'll keep testing it
Guys 3 things :
For what is Anti-BluRay ?
Screenshoting doesn't work over sdcard only over flash ?
How to use the Xposed Statarter pack, do i download the standart xposed apk y so on ?
Screenshot_2014-10-11-00-45-56.pngImage Enlarger
Thanks Oma
Sinuhe
The following users say thank you to sinuhedl for this useful post:
a466604151
2014/10/11 - 10:05
Thank You for feedback!
You will find the Xposed Installer apk and a few usefull modules in the Starter-Pack. Just check it out.
Here is some background on BluRay protection: http://www.screenprotector.cn/anti-blue-protective-film-50.html
v1.1_10.pngImage Enlarger
 v1.1_11.pngImage Enlarger
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2014/10/11 - 16:44
Thank you very much for this Release Oma!
Everything that was buggy is finally fixed in this rom!
YET i am very happy with this tablet, i love it.
Will make expanded tests over the next few days.
THANKS!
gaetanolip
Forum Posts: 28
2014/10/12 - 10:28
Hi
After the update can you rest http://www.libde265.org/downloads-videos/ especially alla bbb videos and http://www.megaupload.com/?d=1D4BX1U9 (for h264 )
Thank you
2014/10/12 - 12:52
What do you like to know?
v1.1_12a.jpgImage Enlarger
 v1.1_14.jpgImage Enlarger
 v1.1_15.jpgImage Enlarger
gaetanolip
Forum Posts: 28
2014/10/12 - 13:54
What do yousmoothe to know?
Thanks oma
are the videos smooth?  (fps? ) do they use how decoder? Please test especially big buck bunny, all videos, because they have the biggest bit rate. Also test h264 video in other link because it is a 40 mbit bitrate
2014/10/12 - 14:10
The other link does not work, but I can play H.264 codes also very smooth.
All is hw decoding in RK-Player, MX-Player, Wondershare-Player.
v1.1_16.jpgImage Enlarger
 v1.1_17.jpgImage Enlarger
2014/10/12 - 15:43
Bitrate is no problem. I can play two 4k videos while downloading in the backgroud ;-)
But hey ... back to topic.
v1.1_20.jpgImage Enlarger
 v1.1_19.jpgImage Enlarger
 v1.1_18.jpgImage Enlarger
hro4649
gaetanolip
Forum Posts: 28
2014/10/12 - 18:05
Thanks oma
Very cool
gaetanolip
Forum Posts: 28
2014/10/13 - 16:38
gaetanolip said
Thanks oma
Very cool
thanhs oma
so this https://mikecanex.wordpress.com/2014/08/03/ifive-mini-4-iambillbil-performance-evaluation/
is not true...
MiGHT.
Germany
Forum Posts: 67
Thanks Received: 13
2014/10/14 - 11:31
Hey Guys,,
keep in mind hat Oma's tests are NOT performed by a iFive Mini 4, he is testing with Teclast P90HD !
Cheers
@Oma, btw.
Can you make an alternative MultiWindow ROM for iFive Mini4? Is this technically possible?
In your ROM 1.1 - i can't install NovaPrime. Any suggestions?
gaetanolip
Forum Posts: 28
2014/10/14 - 14:22
MiGHT. said
Hey Guys,,
Cheers
@Oma, btw.
oma is using a teclast ???? what???? is it true? oma please , asnswer this!!!
might,
do you have an ifivi mini4? can you make same test as oma above??
please , please!!
2014/10/14 - 16:55
Yepp, confirm the tests are done on a Teclast P90HD. However, similar hardware with 2k screen.
2014/10/14 - 17:02
Enable root and /system rw in File Manager HD. Goto /system/app and delete Nova Launcher.
Multi-Window build is here: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rom-pipo-p4-4-4-4-custom-root-firmware-20140809/
Just exchange kernel and resource in folder rockdev/Images.
59 Guest(s)
Devices in use: Desktop (55), Phone (4)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
