ย Please donate to support OMA and CrewRKTablets firmware work, thank you !
[ ROM ] Hisense Vidaa Pad F5281 4.4.4 custom root firmware (2015/01/14)
raymondloo
76
2015/12/20 - 01:30
Hi guys,
I am having some problem with my Sero 8 Pro. The touch screen seems too sensitive. everytime i try to scroll or viewing multiple file, it will accidentally open the file or apps even a very lite touch.
Is there any way to reduce the tocuh screen sensitivity? cause i can't find anyway to calibrate it. Or else any apps can help me on this?
Thanks in advance for this.
ย
Ray
77
2015/12/20 - 09:13
I guess this is more a hardware issue. Check if you can change it with TouchScreenTune (see Play Store).
raymondloo
78
2015/12/21 - 10:09
Thanks Oma for reply. ๐Ÿ™‚
But i still have some others problem which hope members here can help. Thanks in advance for this.
1. Once i get this tablet, i being update the system once by using the system update check ( inside the About phone ). But since i update the 1st time n complete, now when i press the system update, it show network error until now. Is that any alternate way i can download the system update?
2. I am still using the original rom version. Is that any way or guide to install TWRP recovery? ( cause i follow the 12 seconds method but seems the screen only show no command.) Or any way to enter original recovery?
3. My youtube is only able to watch max 720p video however the screen is 2k screen. Any members having same issue?
Thank you so much
79
2015/12/21 - 10:30
You can try a factory reset (settings/backup&reset).
There is a toolset: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-twrpcwm-flash-tool-custom-root-firmware-20150117/
You may have to select 1080p from the resolution menu.
raymondloo
80
2015/12/22 - 17:46
Thanks Oma for the reply.
I am so tired with this tablet due to the screen sensitivity. Already get replacement and yet the problem still the same. The screen is too sensitive. Had try few apps from Google play but nothing help. No way for me to enter hardware test of this tablet. Overall i am satisfied with it but the screen sensitivity is really freaking me up. Put screen protector making it worst.
Really don't know what else i can do...:(
ย
ย
81
2015/12/22 - 17:51
I know it is annoying, but I can only recommend to make use of your warranty.
alucard_
Forum Posts: 15
82
2015/12/23 - 13:11
hi oma
can i flash the rom using twrp or without using the rkbatch tool? if yes, how?
because my OS cannot recognize my sero 8 pro anymore ๐Ÿ˜€
i want to try your rom ๐Ÿ˜€
thanks oma
83
2015/12/23 - 14:14
No. Flashtool is the way. Which Windows?
alucard_
Forum Posts: 15
84
2015/12/23 - 14:15
thanks oma...now it's ok..
i just restart it to bootloader so that my OS can detect it... ๐Ÿ˜€
im flashing now ๐Ÿ˜€
alucard_
Forum Posts: 15
85
2015/12/23 - 15:06
i have oneย  problem... i cannot switch to main camera...only front camera is available...
i also use other camera apps but still the same... no option to switch to main camera...
is there a fix for this problem oma? thanks
ย
other than that your custom firmware is better than the stock ๐Ÿ˜€
86
2015/12/23 - 15:30
This indicates there are tabs with different cams in the field. Do you have a backup of your stock firmware?
alucard_
Forum Posts: 15
87
2015/12/23 - 15:33
yes i have back up using twrp before flashing your firmware
88
2015/12/23 - 15:35
Ok, do not touch this backup in any way. Do a copy and upload it to a filehoster.
alucard_
Forum Posts: 15
89
2015/12/23 - 19:39
locolyric said
still kk .
so i flash your version.
you dont have problem with the camera after you flashed oma's custom firmware?
ย
thanks
90
2015/12/23 - 21:10
Build v1.2: ro.product.version=F5281E1128B1V11 and kernel #9 preempt 11 Dec 2014
Your tab: ro.product.version=F5281E1223B2V03 and kernel #563 preempt 27 Nov 2014
So, I guess build v1.1 (with kernel #565) is closer to your hardware. Anyway, pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2771
109 Guest(s)
2 Guest(s)
Devices in use: Desktop (104), Phone (5)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
