[ ROM ] Hisense Vidaa Pad F5281 4.4.4 custom root firmware (2015/01/14)
61
2015/08/22 - 17:11
Fine. Thank you for feedback!
cynycl
62
2015/09/30 - 17:01
Hi Oma
I have been running your rom on the Vidaa Pad F5281 since you released it and it has been rock solid. Thanks for your hard work.
I was wondering would it be possible to add a spoof file to make the tablet appear as a Nexus 7 tablet for app store purposes? There are some apps that show as not available for this device.
Thanks again
63
2015/09/30 - 17:10
cynycl
jomuc
64
2015/10/15 - 17:38
Hi guys.
I did something very stupid. I flashed TWRP recovery for Sero 8 onto my Sero 8 Pro.
Now I get the "Android bricked" symbol, when I boot the device.
Switch off the device and holding the power button for 12 secs shows the same result.
The PC doesn't detect any USB connection, not as "Rockchip class usb driver" and, of course, also not as a normal USB mass storage 🙁
Is my brandnew Sero 8 Pro bricked?
Do you have any ideas how I can get my device back bootloader mode?
Many thanks for your help.
Joerg.
jomuc
66
2015/10/15 - 20:10
Hallo Oma.
My problem is, that the driver doesn't detect the tablet anymore.
I don't get into the black screen anymore by holding the power button for 12secs:
1. Hisense boot logo is displayed
2. Screen get's shortly black
3. fallen Android with opened service door and red triangle is displayed
No recovery menu. The tablet is dead for the PC. 🙁
Joerg.
67
2015/10/15 - 20:13
Yes, you boot into recovery. This should work (see also instructions):
unplug usb cable, hold Power for 12 sec until screen goes black and plug usb-cable
amcesv
68
2015/10/17 - 15:18
yes!!! after hours of searching I found custom ROM for sero 8 pro
thank you very much oma for your hardwork ...i want to test your build and see the improvements^^
...but do you know how can i install rockchip USB driver on windows 10, i tried this method HERE but it gives me BSOD. any other suggestions?
--lian
69
2015/10/17 - 15:39
Negative. There are no RK dirver for Win10 yet. Pls use a PC with Win7.
amcesv
70
2015/10/17 - 15:53
oh that's bad, don't know where can i find win7 OS here now ... guess i have to wait =( ...but anyways thanks a lot!
71
2015/10/17 - 16:14
You will find an other PC. Waiting on RK might be waiting forever 😉
locolyric
72
2015/12/17 - 15:59
just bought a sero 8 pro . is that posibble to have a cm12.1 on this device?
build quality is really good , for me is better than samsung tab.
but the os part, need more improve.
Hope the Lspeed can tweak it more better.
73
2015/12/19 - 10:08
Is there still KK on it?
locolyric
74
2015/12/19 - 17:49
still kk .
so i flash your version.
75
2015/12/19 - 17:51
What is the running kernel (see settings/About the tab)?
107 Guest(s)
2 Guest(s)
Devices in use: Desktop (96), Phone (11)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
