[ ROM ] Hisense Vidaa Pad F5281 4.4.4 custom root firmware (2015/01/14)
31
2015/03/01 - 22:55
On you win PC you can only mount vfat partitons (via a gadget driver).
LuckyMe
Forum Posts: 29
32
2015/03/01 - 22:57
so my stock rom was vfat and your build is not?
33
2015/03/01 - 22:59
No, your stock rom has the same partition layout.
LuckyMe
Forum Posts: 29
34
2015/03/01 - 23:05
so we're back to square one, aren't we?  WHAT would allow me to see the internal before, but not now?  Because I would like to do that again.  Or are you saying I never did see it?  'cause I did.  Drive f & g.  Now I can only mount g and I can't unmount it.  I can only just unplug the tablet while it's mounted.  I would like to resolve both those issues.
35
2015/03/01 - 23:10
As said in post#15 I cannot answer what was before. However, for what I have found in your dmesg log there was no vfat partition which could be mounted. Sorry again.
LuckyMe
Forum Posts: 29
36
2015/03/01 - 23:12
in fact, about 4 or 5 days ago, drive F did show up in computer under "vidaa" above drive g.  only it was grayed out and when I clicked it it said "access" denied.
loveyounadeem
Dubai
37
2015/03/04 - 11:06
Hey guys,
I have the tablet Sero 8 Pro
I tried all methods including one click root, superroot, root master, and all the other roots possible
but i couldnt root it
So will this surely root my tablet?
and one more thing
if it unifies the internal storage then where does the internal sd card space which is 16 gb is it still there? or it add ups with the external sd card
i mean the 16gb internal sd card is still there, but it cannot be mounted or it cannot be viewed through PC right?
and i have a 32gb external sd card so that will be all the space i have? or i will have 32 + 16 = 48gb?
and if it doesnt work out, how do i recover to the old one?
and if you need more information or inside details about the tablet please let me know :)
and one more thing
will my android version change from 4.4.4 to 4.4.0? or will it remain the same 4.4.4
and one last problem
how do i go recovery mode? i mean i downloaded the custom roam they tell me to go flash modus or recovery mode
but this tablet has no volume buttons or such, how do i go recovery mode?
LuckyMe
Forum Posts: 29
38
2015/03/04 - 14:08
Hi loveyounadeem.
So what happens with your stock rom when you plug it into the pc? Does the MTP User interface open to allow you to choose as media or camera? And most importantly,  can you view interanal and external now?
Oma's build is 4.4.4
And does the sero8 pro have an 8mp back facing camera,  or 5mp?
I don't know about your root question,  Oma will have to answer that. I rooted by tablet using finless Bob's root from freaktab.com
Thanks!
The following users say thank you to LuckyMe for this useful post:
loveyounadeem
LuckyMe
Forum Posts: 29
39
2015/03/04 - 14:13
Ps. Loveyounadeem.
Your internal and external storage will remain the same. You just can't access the internal when plugged in with usb. BUT you can access it on your PC wirelessly. I am using airDroid from google play. There are other apps to use too. Esfile 3 should be able to do it. But I can't get it to accept my ip address. Maybe it would work for you.
loveyounadeem
loveyounadeem
Dubai
40
2015/03/04 - 14:33
LuckyMe said
Ps. Loveyounadeem.
oh i see
one more thing
do you know how to go recovery mode? in this tablet sero 8 pro
did u install the custom rom? if u did please tell me how because i am not been able to install
41
2015/03/04 - 17:10
Can you pls post screenshots of
- settings/About tab
- settings/storage (complete right side should be 3 screenshots)
- settings/storage/"three dots"
LuckyMe
Forum Posts: 29
42
2015/03/04 - 17:32
And today Oma, my tablet can see both!  I hope it works continuously.
Image Enlarger
LuckyMe
Forum Posts: 29
43
2015/03/04 - 17:40
I deleted the USB host controller application that came pre installed on the ROM.  Maybe it's not compatible.  I don't know.....
but it's working properly at the moment.
44
2015/03/04 - 17:44
Well, this is the symlinc. You are in MTP mode now.
loveyounadeem
Dubai
45
2015/03/07 - 16:11
Well thank guys for your help
Especially LuckyMe for providing me the simpliest root ever!
Thanks OMA but i didnt try your custom rom as it was too much work needed to do
i did
http://www.freaktab.com/showthread.php?17382-NEW-gt-3288-EZ-Root-Tool
so easy and rooted my tab nice and clean :)
86 Guest(s)
Devices in use: Desktop (80), Phone (6)
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
mantonero
