[ ROM ] Hisense Vidaa Pad F5281 4.4.4 custom root firmware (2015/01/14)
LuckyMe
Forum Posts: 29
2015/03/01 - 21:54
mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),
0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),
0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),
0x00200000@0x00092000(system),0x00002000@0x00292000(metadata),0x00020000@0x002A4000(radical_update),
-@0x002C4000(userdata)
This is your partition layout. No user partition (internal sdcard). Consequently it cannot be mounted.
so where was this retrieved from?
this?:
We can dump the firmware on the tab. Download a terminal emulator from Play Store, reboot tab and type:
su
dmesg >/mnt/sdcard/dmesg.txt
cat /proc/partitions >/mnt/sdcard/partitions.txt
2015/03/01 - 21:58
Yes, you will find the kernel command line in the dmesg log.
LuckyMe
Forum Posts: 29
2015/03/01 - 22:02
so what does that mean?  Are you saying the kernel doesn't support mounting of the internal storage?
2015/03/01 - 22:07
No, I am just saying you can find the partition layout in the dmesg log. I shows clearly what the physical partition layout on your NAND was.
LuckyMe
Forum Posts: 29
2015/03/01 - 22:10
so possibly I didn't run the commands properly, or I did something wrong, I neglected to run something?  which would be the internal partition? or something?
2015/03/01 - 22:12
Your running kernel didn't lie. Typically the partiton /user is called internal sdcard.
LuckyMe
Forum Posts: 29
2015/03/01 - 22:16
so if it's not called internal sd what is it called in my tablet?
2015/03/01 - 22:18
According to your partition layout it is not there.
LuckyMe
Forum Posts: 29
2015/03/01 - 22:28
what?  my tablet doesn't have ANY internal storage?  Doesn't that seem odd to you?  like something isn't right?  Are there even tablets like that?
2015/03/01 - 22:31
Right, internal sdcard isn't there. An unified internal storage is google standard nowadays.
LuckyMe
Forum Posts: 29
2015/03/01 - 22:33
Image Enlarger
there it is - sd 0
Image Enlarger
2015/03/01 - 22:37
This is an (Android) emulated one. It is physically not there.
LuckyMe
Forum Posts: 29
2015/03/01 - 22:40
because it says "0" and not "sdcard 0" ?
2015/03/01 - 22:43
No, this is an emulated partition on an ext4 partition. Internal sdcard was a vfat partition.
LuckyMe
Forum Posts: 29
2015/03/01 - 22:51
so why could I access both internal "emulated" storage and external sdcard before, but now I can only access the external?  I need a vfat partition?
94 Guest(s)
Devices in use: Desktop (88), Phone (6)
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
mantonero
