Gents,
This is my first build for Hisense Vidaa Pad F5281
Build is based on a stock dump, dated 01. Dec 2014 and kernel #565 preempt 25 Nov 2014.
Thanks to LuckyMe for providing the dump and testing the build!
Please do NOT use this build on Hisense Sero 8 Pro, which is coming with kernel #9 preempt 11 Dec 2014.
>>> Build for Hisense Sero 8 Pro build see post #59 😉
– stock recovery 4.4.0
– kernel #565
– unified internal storage
– init.d support
– RebootMenue, sEFix, FX Sound
– Dateimanager HD (Root)
– Nova Launcher
– full google apps support, incl. Play Store
Hints:
– Oma -
cynycl, LuckyMe, loveyounadeem, prestack, christian_death, amcesvPer aspera ad astra, we rock the Tablets !
You can ask LuckyMe for the dumps ... but I guess you won't have this creapy stock firmware back
No gapps support, crap launcher, unreadable system fonts, no soft volume keys for a tab without volume rockers, etc.
Can someone help me resolve this issue? When I connect to the PC as a media player/for transferring files and data, I can only access external storage. I used to be able to choose internal or external.
Also after clicking "turn on usb storage" it never stops searching, so there isn't a way to turn it off. I have to just unplug the tablet. Then the next time I plug in, the PC wants to scan my sd card.
It never stops searching. Presumably for the driver (?)
So where do I find this missing driver?
thanks!
The build has an unified internal storage. So there is no internal sdcard (vfat partition) which you can mount.
No changes against stock.
Well, this is the dump of your stock rom. And this has an unified internal storage. So, no internal sdcard.
mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),
0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),
0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),
0x00200000@0x00092000(system),0x00002000@0x00292000(metadata),0x00020000@0x002A4000(radical_update),
-@0x002C4000(userdata)
This is your partition layout. No user partition (internal sdcard). Consequently it cannot be mounted.
I do not have the tab, nor any experience with it. So, I can only analyse what you have provided. I did explain that simple and then technically. Sorry for be not more helpful.
66 Guest(s)
Devices in use: Desktop (58), Phone (8)
