[ ROM ] Archos Oxygen 101 4.4.4 custom root firmware (2015/01/15)
2015/08/13 - 15:12
Only for this build. LP needs an other kernel.
AC2N
Forum Posts: 11
2015/08/13 - 15:28
I don't know what is LP ? Do you think it's possible to build a lollipop rom for my tablet Qilive Q-3253, clone of Archos 101 oxygen because your build is the same Android that is installed on my Qilive.. Sorry for my English I'm french.. And thanks yet..
2015/08/13 - 15:34
LP := Lollipop 😉
LP is not possible on your tab as long as there is no LP kernel (or at least LP kernel sources).
AC2N
Forum Posts: 11
2015/08/21 - 15:47
Thanks Oma..
 Your build work fine on my Qilive Q-3253, great job.. Now I'm waiting a LP ROM..
AC2N
Forum Posts: 11
2015/08/21 - 17:27
But there is no update menu like before
2015/08/21 - 17:38
What do you mean by update menue?
AC2N
Forum Posts: 11
2015/08/21 - 20:25
In the setting, in the section about the tablet I had a button to check the update of the system. But now there are none.. Now I can't check if Archos have made update for my tablet.. It's not very important now I check on this forum..!  Thanks you again for all..
AC2N
Forum Posts: 11
2015/08/22 - 15:20
2015/08/22 - 15:22
Be careful. This is a fake or more ...
lynx666
2016/01/15 - 17:59
I have an 101 oxygen, I have installed the custom root firmware (thanks for your work) but the screen touch don't reacted properly.
When I touch the screen on the left, reaction on the right (axe X, left right reversed / axe Y is ok  mode landscape)...
I can't reinstall , my original backup is lost (mishandling) and the update-from-archos.zip don't want to install (E:failed to verify whole-file signature....)
Sorry for my poor english and thanks
2016/01/16 - 17:00
Flash again incl. LowerFormat.
lynx666
lynx666
2016/01/18 - 16:32
Hello, thank for your help.
I' ve reflash several times, under w7 and an another pc (with lowerformart), but the problem stay the same.... Axe X reverse, I can' t find a solution ( I've test the two kernel)...if you have an idea....
2016/01/18 - 16:59
Sounds like the touch controller is flashed with a wrong firmware. Did you flash a strange kernel into the tab?
lynx666
2016/01/18 - 17:56
 No, just flashed tablet with your firmware and test the 2 kernel , new tablet received the past week with original firmware.I don t understand....with original firmware I have no problem.
2016/01/18 - 18:22
Which kernel is on the new tab?
99 Guest(s)
Devices in use: Desktop (88), Phone (11)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
