[ ROM ] Archos Oxygen 101 4.4.4 custom root firmware (2015/01/15)
2015/01/16 - 13:09
Gents,
This is my first build for Archos Oxygen 101 ;-)
Build is based on a beta stock, dated 07. Jan 2015 and kernel #646 preempt 07. Jan 2015.
Oxygen by Oma build v1.0
– stock recovery 4.4.0
kernel #646
– unified internal storage
– multi-user
– init.d support
– RebootMenue, sEFix, FX Sound
– Dateimanager HD (Root)
– Nova Launcher
Hints:
use Nova launcher and set animation/scroll to “faster than light” and
enable Entropy Fixer with value 256
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
v1.0_logo.pngImage Enlarger
 084-1.jpgImage Enlarger
 Oma-RK32-Oxygen-build-v1.0-15.01.2015.pngImage Enlarger
 v1.0_home-2.jpgImage Enlarger
v1.0_apps-3.jpgImage Enlarger
 v1.0_antutu-1.pngImage Enlarger
TWRP_CrewRKTablets_v2.1_1-1.jpgImage Enlarger
cajl
Forum Posts: 70
Thanks Received: 5
2015/01/27 - 19:37
Great !
Where are you buy this Archos, i do not in your rom the Archos Applications....
or it is a rom from Pipo P9 or M8
see that http://www.jbmm.fr/2015/01/test-de-la-tablette-pipo-p9-en-attendant-larchos-101-oxygen_1938
2015/01/27 - 20:33
As far as I know the PCB is close to P7, the screen is from P9 and the housing is well known from M8.
Anyway, we will see a wide brunch of such customized tabs (for Archos, Krüger&Matz, Qilive ...) in the near future.
- Om -
2015/06/03 - 18:32
New kernel #667 preempt 03. Mar 2015: http://crewrktablets.arctablet.com/?wpfb_dl=2557
AC2N
Forum Posts: 11
2015/08/09 - 10:42
I, can i install this ROM on my Qilive Q-3253 who is the clone of Archos 101 oxygen.. Thanks.
AC2N
Forum Posts: 11
2015/08/09 - 17:35
I have already rooted my tablet and make a full backup with twrp..
2015/08/09 - 17:40
A dump of the images and the full logs would be better ...
We need at least boot, resource and kernel from the TWRP backup.
AC2N
Forum Posts: 11
2015/08/09 - 17:43
And haven't sucess with root and dump firmware... 🙁
2015/08/09 - 17:48
Ok, then zip boot, kernel and resource from the TWRP backup and upload it here.
AC2N
Forum Posts: 11
2015/08/09 - 20:49
Ok, this is .rar of my backup.. Thanks a lot... This tablet is very similar with Pipo P9, can I install lollipop ROM like pipo p9 ?
2015/08/10 - 18:18
I have removed the attachment because the backup does contain your personal data.
Also the archive seems to be corrupted. Pls upload only the three files.
rar.pngImage Enlarger
AC2N
Forum Posts: 11
2015/08/11 - 08:17
OK i'm sorry, this is only boot, kernel and ressource.. Thanks Oma for all you do..
2015/08/11 - 17:38
Ok, should work. Here is Qilive Q-3253 kernel and resource. Just change in folder rockdev/Image before flash.
AC2N
Forum Posts: 11
2015/08/13 - 13:21
Thanks a lot, I suppose that it's only for this build.. Or can I flash lollipop rom for Pipo p9 with your kernel and resource files ?
Currently Online: vishu bhatnagar
58 Guest(s)
Devices in use: Desktop (58), Phone (1)
vishu bhatnagar
djwood1014
4ipolino
thomashansmuller11
abro
Yoyoo
