Simple tool to Root and Dump the stock firmware via PC.
If you'd like you can upload the files and post a link here. I will check if anything is ok.
Yes.
2015/02/22
alexxa said
So if I root my teclast p90hd tablet with this tool (i have stock rom) i dont need to install any other rom, but my tablet is then rooted?
No, sorry, it doesn't work for me.
Yesterday I flashed stock rom for the teclast p90hd (A6K7) and tried to root with this tool. Sadly, it didn't work.
The tool flashed all apps, but not busybox. After booting supersu says "it couldt not work on this device without root permissions"
I had to use iRoot, but i can't recomment this tool without a strong security suit - it's maleware inside!
2015/05/12
Hi Oma,
I was going to dump my stock fw, but adb can't see the box, hence can't do it...
I uninstalled and installed the driver as you instructed, and i can see the adb interface in windows' device manager.
Box has been reset, then power off on, adb still can't communicate.
Any suggestions?
Thanks!
EDIT: Managed to get it connected after using another driver assistant...
I'll upload the rom dump soon!
2015/05/12
Hi Oma,
Here is a link with my dump...
https://www.dropbox.com/s/faolffwbbkee6f7/rom_dump_Q8.zip?dl=0
One question: could you tell me from this dump which roms are compatible?
Thanks!
90 Guest(s)
Devices in use: Desktop (76), Phone (13), Tablet (1)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
