[ RK3288 ROM ] Vido M11pro Android 4.4.2 custom root firmware (2014/11/17)
2014/11/20 - 15:18
Gents,
This is my first build for Vido M11pro ;-)
Build is based on stock dated 12. Nov 2014 and kernel bob #262 preempt 13. Nov 2014.
M11pro by Oma build v1.0
update 19.03.2015: kernel #391 (change kernel/resource in folder rockdev/Images before flash)
update: kernel bob #277
update: kernel bob #274
– stock recovery 4.4.0
– kernel bob #262
– 4 GB internal storage
– init.d support
– Dateimanager HD (Root)
– Nova Launcher
Hints:
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
v1.0_02.pngImage Enlarger
 v1.0_01.pngImage Enlarger
 v1.0_03.pngImage Enlarger
2014/11/24 - 19:51
Post #1 updated with new kernel #270 preempt 20. Nov 2014: http://crewrktablets.arctablet.com/?wpfb_dl=2266
2014/11/29 - 16:57
Post #1 updated with new kernel #274 preempt 26. Nov 2014: http://crewrktablets.arctablet.com/?wpfb_dl=2273
--CoolZone--
Forum Posts: 14
2014/11/30 - 21:16
Hi Oma,
Flashed this firmware successfully, but I am encountering battery issues with it. While the tablet off, the battery indicator shows full bars but as soon as I boot the rom, it shows only about 35-40%. If I keep the battery charging for a very long time, it will reach eventually 100% but as soon as I start using it and drops under 90%, it will then instantly drop to 1% and shut down (again, when off it will only show as 75% full and not all battery goes out).
Any idea why the battery calibration is so bad when using this rom on the E-CEROS Revolution 2?
Thanks in advance!
2014/11/30 - 21:24
The change-log from kernel #274 states something like "optimized charging problem solving" (google translated).
Which kernel do you use?
--CoolZone--
Forum Posts: 14
2014/11/30 - 21:31
Hi Oma,
I have last flashed the 274 kernel. Right now the battery shows full when the tablet is off and 37% (charging) when the tablet has booted up. It barely goes over 37% since obviously the tablet is fully charged.
2014/11/30 - 21:40
Ok, let the tab fully loaded and then do a factory reset (settings/Backup & reset/Factory data reset). This will also wipe the battery stats. May be its only a missmatch.
You can also try this older CT9717 kernel #152: http://crewrktablets.arctablet.com/?wpfb_dl=2284
--CoolZone--
Forum Posts: 14
2014/11/30 - 21:49
Will do so and report back if it gets fixed. Thanks!
--CoolZone--
Forum Posts: 14
2014/12/01 - 11:00
It seems that only the old kernel has fixed the problem, others do not work well.
2014/12/01 - 18:45
Fine. If there are other Revolution 2 users around, pls let us know what kernel is on the tab.
--CoolZone--
Forum Posts: 14
2014/12/02 - 05:46
Done a screenshot right before flashing the firmware, so I can help. Originally, the tablet has arrived with the 3.10.0 Kernel:
bob@bob-desktop #317
Wed Nov 5 14:32:20 CST 2014
2014/12/02 - 16:05
Ok, can somebody dump the kernel?
Download a terminal from Play Store and type:
dd if=dev/block/mmcblk0p3 of=/mnt/external_sd/resouce.img bs=4096
dd if=dev/block/mmcblk0p4 of=/mnt/external_sd/kernel.img bs=4096
Zip the files and upload it here. I will check.
2014/12/13 - 17:22
Post #1 updated with new kernel #277 preempt 8. Dec 2014: http://crewrktablets.arctablet.com/?wpfb_dl=2297
2014/12/15 - 21:31
@ --CoolZone--
Here is the latest E-CEROS Revolution 2 (CT9717) kernel #338 preempt 22. Nov 2014: http://crewrktablets.arctablet.com/?wpfb_dl=2308
82 Guest(s)
Devices in use: Desktop (75), Phone (7)
