2016/09/06
I am a noob to all of this and I have gotten my tablet (insignia flex elite) in a boot loop so I decided to try to flash a rom to it. The only problem is that I can't get it to work. I believe it is a problem with the driver. When I open the android tool it detects the device but it can't flash anything to it. It says "Test device start" then "Test device fail". Thank you for any help
The Insignia is not an easy one. Pls read this thread carefully: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-insignia-flex-elite-lp-5-0-2-custom-root-firmware-20150808/page-3/?lang=fr#p55534
2016/09/15
I have a question. i have try with my Archos 101 b Oxygen (the one with 32Go space and Marshmallow 6.0).
All is ok but the Android tool don t detect any device. I have try with Power on , power off then Vol Up but nothing change.
With adb fastboot i see my device without problem but i don't have any good img file for a CWM or TWRP.
If some one have a solution that would be great.
So, you have a 101b Oxygen running stock Marshmallow?
I did not see any rk32board running a MM stock firmware. So, I cannot confirm.
2016/04/18
Hi Oma,
well done for your job!!!
I've a qilive and few years ago I've flash with this rom with no hickups since.
Recently I'm having problem with the touch screen and I believe it is a SW issue.
As revovery I've installed TWRP and I don't have a windows machine to flash again the tablet while I was wondering how I can make a .zip file and re-install the system with TWRP.
I've already tried a factory reset but not much has changed so fresh installation would be the next option
any suggestion is welcome
thanks
47 Guest(s)
Devices in use: Desktop (40), Phone (7)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
