The Android on his back is the result of starting the stock recovery. As said before the stock recovery does not have any other functionallity then formatting the user partitions.
The instructions describes to start a recovery under point 5).
Fine. Thank you for feedback! Which device do you have?
I cannot do anything in this case. Your kernel does not support touch in this stadium.
Ok, thank you for feedback. Post #1 updated.
Archos Magnus 101 is a Mediatek architecture and Archos Magnus 101 Plus a Rockchip architecture ... great!
I guess the Plus is an Archos Oxygen 101 with 126 GB memory. So, yes it will work.
Pls make sure you have the genuine firmware available before touching anything.
Our server was down. Sorry for that. Pls try again.
2016/08/19
Our server was down. Sorry for that. Pls try again.- Oma -Â Â
Hello Oma. Thanks for brought the server back. I was desperately need this tool for my Pipo P1. However, I was noticed that there is a 3.0 version of the flash-tool archive called "CrewRKTablets_RK32_LP_TWRP_CWM_Root_v3.0.7z" on your site. Is this the later version of "CrewRKTablets_RK32_TWRP_CWM_Root_v2.2"? I am not sure what the "LP" means. Could I use it for my P1?Â
Depends on what do you are running on P1. LP does mean Lollipop. MM = Marshmallow build is here: http://crewrktablets.arctablet.com/?p=6101
55 Guest(s)
3 Guest(s)
Devices in use: Desktop (50), Phone (5)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
