gffmac said
Maybe I need to install rom from AndroidTool first to set the partitions then restore my backup?
Yes, that's the way.
2013/05/23
@Oma,
I am Charlie also, should have been more specific about TWRP the 1920 x 1080 does not consider the header and needs to be 1920 x (1068)?. I am using the Netlars Root, something about that just sounds wrong, along with TWRP 1280 x 800, with no problems or complaints.
---cappybob
2013/03/10
Curious ... you stated earlier that the touch is not working. Mounting internal sdcard is not possible when you have an unified internal storage. The error shown is unimportant. System seems to bee corrupted somehow. Anyway, I will repack the Vidaa Pad build later today.- Oma -
Hi.
Want to leave a feedback for Beelink R89 (RK3288, 2GB RAM/16GB ROM). I have custom firmware installed (Wasser, version 2.0.4 at the moment), it has unified partition. I'm unable to backup firmware since I have no place: internal_sd is not moutable, as you just said, and USB storage is also cannot be mounted. Would you mind looking into this matter, please?
P.S. I'm using "CrewRKTablets_TWRP_1920x1080_v2.1.img" for recovery and since it's working fine with Tronsmart R28 (which is the same with Beelink R89), I assume it has something with unified partition.
TWRP 2.8.4.0 is out: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-twrpcwm-flash-tool-custom-root-firmware-20150117/
Now all resolutions are available: Landscape 1280x800, 1920x1080, 1920x1200, 2048x1536, 2560x1600 and Portrait 800x1280, 1200x1920, 1536x2048, 1600x2560. Also some themes
Just use the default storage external_sd.
Yes, with stock the 1920 x 1200 touch didn't respond. I rebooted and boot to recovery a couple of times, same response. I then flashed 1200 x1920 with the same results.
After flashing your build, and again taking MANY tries to get the tablet to be recognized, I reflashed 1200x1920, and now the touch works.
The tablet no longer can be recognized on the PC as a media device, or camera, as before. I can only now transfer photos to the usb device. (Or unmount and remove the sd card)
You say the system is corrupt. So does this mean I can flash just boot, and system.img with the tool to fix it?
Or maybe flash your build again, and then restore data with twrp?
Thank you.
Laura
2019/11/24
Please check this topic for latest TWRP 2.8.4.0 Gents,
this a Flash-Tool by CrewRKTablets which provides:
a) generic TWRP's 2.8.3.0 for landscape and portrait orientation
b) a generic CWM 6.0.5.1
c) a root-script to be installed via TWRP/CWMSo, it can be used on any rk32board and to root any rk32board
- generic, that means no kernel and resouce included in the image
- full touch and usb-mouse support (not supported by some kernel)
- volume rockers support (only CWM)
- backup and restore of all partitions (boot, kernel, resource, recovery, system, data)
- backup and restore of internal sdcard (only TWRP)
- advancend restore (i.e. restore data)
- advanced backup (only TWRP)
- install zip from external sdcard (i.e root-script, gapps, fixes)
- wipe (factory reset) and advanced wipe
- some more functions, which we do not need (so, untested)Flash instructions are included in the download pack.
Tested on / confirmed installation on:
- Pipo P9 (CWM, TWRP 1920x1200)
- Pipo P8 (CWM, TWRP 1200x1920)
- Pipo P7 (CWM, TWRP 1280x800)
- Pipo P4 (CWM, TWRP 1920x1200)
- Pipo P1 (CWM, TWRP 1920x1200)
- iFive Air (CWM, TWRP 1200x1920)
- iFive Mini4 (CWM, TWRP 1200x1920)
- Vido M11pro (CWM, TWRP 1200x1920)
- Teclast P90HD (CWM only, kernel supports no touch)
- Hisense Vidaa Pad F5281 ... see herenew: sticks/boxes: TWRP for 1080p (load it into the AndroidTool by clicking on the empty box at the end of a line)
Tronsmart R28
FAQ
Q: why can TWRP not mount internal sdcard?
A: working on/with internal sdcard (partition on the NAND) does not make senes; it is disabled in the code for the advantage to backup/restore the internal sdcard. So, one must not loose all the obb and data files of games like Asphalt etc.. Btw. Google standard is an unified internal storage, so no internal sdcard any longer
Q: why can I not shut-off the tab from TWRP?
A: design intend of these tabs is to only shut-off when all cable are unplugged.
– Oma -
Where to find this Flash-tool? Say its gone? My internal memory is 0 MB when try to flash xposed zip from twrp 3.1.1.0 recovery on CS918plus rk3288 with 5.1.1 lolipop.. Thanks
73 Guest(s)
Devices in use: Desktop (66), Phone (7)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
