[ RK3288 ROM ] TWRP/CWM Flash-Tool custom root firmware (2015/01/03)
TWRP 2.8.3.0
Thanks Received: 1385
2015/01/09 - 21:29
Please check this topic for latest TWRP 2.8.4.0
 Gents,
this a Flash-Tool by CrewRKTablets which provides:
a) generic TWRP's 2.8.3.0 for landscape and portrait orientation
b) a generic CWM 6.0.5.1
c) a root-script to be installed via TWRP/CWM
So, it can be used on any rk32board and to root any rk32board ;-)
- generic, that means no kernel and resouce included in the image
- full touch and usb-mouse support (not supported by some kernel)
- volume rockers support (only CWM)
- backup and restore of all partitions (boot, kernel, resource, recovery, system, data)
- backup and restore of internal sdcard (only TWRP)
- advancend restore (i.e. restore data)
- advanced backup (only TWRP)
- install zip from external sdcard (i.e root-script, gapps, fixes)
- wipe (factory reset) and advanced wipe
- some more functions, which we do not need (so, untested)
Tested on / confirmed installation on:
- Pipo P9 (CWM, TWRP 1920x1200)
- Pipo P8 (CWM, TWRP 1200x1920)
- Pipo P7 (CWM, TWRP 1280x800)
- Pipo P4 (CWM, TWRP 1920x1200)
- Pipo P1 (CWM, TWRP 1920x1200)
- iFive Air (CWM, TWRP 1200x1920)
- iFive Mini4 (CWM, TWRP 1200x1920)
- Vido M11pro (CWM, TWRP 1200x1920)
- Teclast P90HD (CWM only, kernel supports no touch)
- Hisense Vidaa Pad F5281 ... see here
new: sticks/boxes: TWRP for 1080p (load it into the AndroidTool by clicking on the empty box at the end of a line)
Tronsmart R28
FAQ
Q: why can TWRP not mount internal sdcard?
A: working on/with internal sdcard (partition on the NAND) does not make senes; it is disabled in the code for the advantage to backup/restore the internal sdcard. So, one must not loose all the obb and data files of games like Asphalt etc.. Btw. Google standard is an unified internal storage, so no internal sdcard any longer ;-)
Q: why can I not shut-off the tab from TWRP?
A: design intend of these tabs is to only shut-off when all cable are unplugged.
– Oma -
a-flash_recovery.jpgImage Enlarger
  TWRP_CrewRKTablets_v2.1_1.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_2.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_5-3.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_3-7.jpgImage Enlarger
 TWRP_CrewRKTablets_v2.1_4-5.jpgImage Enlarger
 b-install_zip.jpgImage Enlarger
CWM_CrewRKTablets_v1.1-1.jpgImage Enlarger
 CWM_CrewRKTablets_v1.1_1-8.jpgImage Enlarger
 CWM_CrewRKTablets_v1.1_2-1.jpgImage Enlarger
admin, lavinski
Thanks Received: 3170
2015/01/10 - 16:51
Excellent ! works perfect on a PiPO P4 Laugh
Tested CWM 6.0.5.1 Recovery and TWRP 2.8.3.0 Recovery (1920x1200), here are a few pictures:
TWRP starting logo:
CrewRKTablets_TWRP_2_8_3_0_PiPO_P4_home_logo_DSC_0169.jpgImage Enlarger
TWRP main menu, touch screen works perfect:
CrewRKTablets_TWRP_2_8_3_0_PiPO_P4_home_DSC_0167.jpgImage Enlarger
TWRP backup complete:
CrewRKTablets_TWRP_2_8_3_0_PiPO_P4_backup_DSC_0171.jpgImage Enlarger
TWRP restoring, select the backup to restore:
CrewRKTablets_TWRP_2_8_3_0_PiPO_P4_restore_select_DSC_0174.jpgImage Enlarger
 TWRP restore complete:
CrewRKTablets_TWRP_2_8_3_0_PiPO_P4_restore_complete_DSC_0177.jpgImage Enlarger
CWM main menu:
CrewRKTablets_CWM_6_0_5_1_PiPO_P4_home_DSC_0180.jpgImage Enlarger
CWM backup in progress:
CrewRKTablets_CWM_6_0_5_1_PiPO_P4_backup_DSC_0183.jpgImage Enlarger
CWM backup complete:
CrewRKTablets_CWM_6_0_5_1_PiPO_P4_restore_complete_DSC_0189.jpgImage Enlarger
CWM Restore in progress:
CrewRKTablets_CWM_6_0_5_1_PiPO_P4_restore_in_progress_DSC_0186.jpgImage Enlarger
2015/01/10 - 17:00
Cool. Thank you for feedback and the pictures!
Pipo P4 to tested devices added in post#1.
cappybob
Forum Posts: 79
Thanks Received: 8
2015/01/10 - 20:27
As usual NICE.  Worked on my Firefly and really needed there.  Used CWM and the ROOT. Liked the new use for the rktools, didn't know that it could be used like that.
thanks to Netlars.
----cappybob
2015/01/11 - 09:23
Great. Thank you for feedback!
Did you also test TWRP?
cappybob
Forum Posts: 79
Thanks Received: 8
2015/01/11 - 17:40
Yes Oma, had to.  CWM worked only off and on after a cold start.  TWRP worked much better and combined with a reboot menu APP, one can completely ignore the button push routines.
----cappybob
2015/01/11 - 17:43
Fine. I guess it is more or less regardless which resolution do you run?
Edit: on after hard power-off is driven by the kernel. We see that also on some tabs.
gffmac
2015/01/12 - 23:03
I have this running on my Tronsmart Orion R28 Meta RK3288. Internal_sd dont mount but apart from that it seems fine is there any chance of getting a 1920x1080 version??  Thanks for your work.
Tronsmart airmouse works fine in recovery.
bluesmanuk
2015/01/13 - 00:49
Installed fine on my Tronsmart Orion R28 Meta and internal_sd does not mount, which I can see is intended, although I am not convinced by the reasoning.
USB Storage does not mount from the main mount menu and when I select the Mount USB Storage button it take me to a screen where there is only the unmount button available, so unable to go back to the previous screen without having to unmount it and therefore unable to backup to usb storage.
When selecting Power Off from the Reboot menu it just reboots rather than powering off, which again I can see is intended but if it can be done from within Android, I do wonder whether it can still be possible via TWRP.
If it cannot be done then removing the option would be best.
Backup of all 8 partitions did seem to work well.
LuckyMe
Forum Posts: 29
2015/01/13 - 20:07
Hi.  Sorry if I sound like a noob.  But I am, with rockchips.
I have a VIDAA 8" PAD tablet from china.  I can't access recovery, and I don't have any volume keys.  reboot apps only bring me to the screen with the droid on his back with the red triangle. I can't get past this screen.  ADB and terminal emulator won't work either. (is it possible not to have a recovery?? )
I'd like to put TWRP touch on the tablet.
first question: will this work for me?
RK3288
android 4.4.4
2047 x 1536
2gb/16gb
second question:  this is flashed with the rockchip tool?
thank you in advance.
Laura
2015/01/13 - 20:28
Thank you gffmac & bluesmanuk for feedback! Let me explain/comment a little bit that we come into a discussion.
What is a valid reason to restore a backup? When the build is crashed or you try a new/other firmware. In both cases you have to wipe the NAND. So, internal sdcard (partition on the NAND) is lost. That's why we think working on/with internal sdcard is not very useful. On the other hand you have most likely game data (obb and user) on the internal sdcard, which will also get lost. Disabling the internal sdcard in the TWRP code will give the benefit to also backup/restore the internal sdcard.
So, in other words our backup/restore strategie is: all partitions on the NAND >>> exclusively to external sdcard.
TWRP_CrewRKTablets_v2.1_5-4.jpgImage Enlarger
Mounting of an usb storage is untested, maybe we will enable this in the next build.
Rebooting options depends on the power management chip and it's programming. In some cases proper function of the chip is not independend from the kernel because the kernel flashes every times code in the chip. The majority of the tabs comes with an always power on strategie, which means only Power Button and USB-port to communicate with the loader. That's the reason why these tabs boot into Android when usb cable will plugged in. Also tab will not shut down when usb cable is plugged. So, that's not an kernel issue it is a kernel feature. However, no idea of what the design intend of a stick/box is  ... when there is one.
But hey, when you restore a backup your next step is not to Power-Off, is it?
What about using the 1280x800 resolution? There are not for all resolution standard themes. Adjusting a theme is a lot of work. Attached one standard theme .. if somebody have skills and time ;-)
LuckyMe
Forum Posts: 29
2015/01/13 - 20:36
so could I do that?  use like, the 1900 x 1200?  Maybe it would just be small on my screen???  but still work?  Or it just not that easy to solve for me?
gffmac
2015/01/13 - 20:40
Thanks Oma,
I did mange to find a 1920x1080 theme based on stock, not sure if all options are there i.e. if its optimised for an old version of twrp.
Here it is https://dl.dropboxusercontent.com/u/12260218/ui.zip
2015/01/13 - 20:44
RK3288
android 4.4.4
2047 x 1536
2gb/16gb
What you see (droid on his back) is the stock recovery. It has only the function to format the user space on the NAND. That's all.
Both answers to your questions are yes.  If your kernel logo is in portrait then use 1200*1920 otherwise 1920*1200.
If you like to retain the stock firmware first contact me via PM.
LuckyMe
Forum Posts: 29
2015/01/13 - 20:48
ok, THANK YOU!
happy dance!
71 Guest(s)
Devices in use: Desktop (66), Phone (4), Tablet (1)
jenom
kfwacky
fer30
culo1
dfrt
PQNY
