Not really an idea. Does the card work with stock?
Pls boot tab fresh and provide a dmesg log.
Just reboot, I need the start-up sequence.
You can use tools like this: http://forum.xda-developers.com/showthread.php?t=1944776
2015/02/22
You can use tools like this: http://forum.xda-developers.com/showthread.php?t=1944776- Oma -
send the file via PM.
<6>[ 1.202961] mmc1: new high speed SDXC card at address e624
<6>[ 1.203157] mmcblk1: mmc1:e624 SU64G 59.4 GiB
Kernel initializes the card. But no mounting. Can you pls post a screenshot of settings/storage?
2015/02/22
Ok, could be some wake lock issues. Pls install this app: https://play.google.com/store/apps/details?id=eu.thedarken.wl&hl=de, set to "partial wake lock" and go on with testing.- Oma -
this solution raises the battery usage very much, because the tablet will never fall in deep sleep.
curiously the issue exists further after flashing stock rom from omnirom. :/ would be great if someone has another idea to solve that bug.
2014/12/12
VincAlastor said
this solution raises the battery usage very much, because the tablet will never fall in deep sleep.curiously the issue exists further after flashing stock rom from omnirom. :/ would be great if someone has another idea to solve that bug.
On the iFive Air, I've worked around the wifi bug buy just setting the option in settings to allow the device to still scan for wifi even when wifi is turned off. Then you can turn wifi off and still get deep sleep. I have to assume it doesn't save as much battery as actually turning it off all the way, but at least it will still turn back on when the device wakes up.
iFive Air (32GB) - XDA Discussion -- (including my iFive Air Nexus ROMs based on stock)
75 Guest(s)
Devices in use: Desktop (67), Phone (8)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
