[ RK3288 ROM ] Teclast P90HD OmniROM 4.4.4 custom root firmware (2014/12/06)
This is a generic build for rk32boards.
Thanks Received: 1385
2014/12/28 - 22:12
Here we go: http://crewrktablets.arctablet.com/?wpfb_dl=2331
Build v1.1 has working hwcomposer and comes with generic testbuilds of CWM 6.0.5.1 and TWRP 2.8.3.0. Both have touch support.
On P90HD only CWM will work due to missing touch event of the stock kernel. Use the volume rockers to navigate.
Build and recovery should work on any stock kernel. Pls report back any issue. Thx!
CrewRKTablets_RK32_Teclast_P90HD_Omni_4.4.4_v1.1.pngImage Enlarger
 v1.1_omni-switch.jpgImage Enlarger
 v1.1_antutu_b.pngImage Enlarger
 CrewRKTablets_CWM_v1.0_02-1.jpgImage Enlarger
 CrewRKTablets_TWRP_v2.0_04-1.jpgImage Enlarger
 CrewRKTablets_TWRP_v2.0_03-1.jpgImage Enlarger
 v1.1_kitkat_A.pngImage Enlarger
Kingess
Forum Posts: 11
2014/12/29 - 23:50
Thank you very much for this upload.
Unfortunatly, the tablet is still rebooting when I lock it... So I think this rom if over for this P90HD right ?  :/
2014/12/30 - 14:44
Ok, could be some wake lock issues. Pls install this app: https://play.google.com/store/apps/details?id=eu.thedarken.wl&hl=de, set to "partial wake lock" and go on with testing.
Kingess
Forum Posts: 11
2014/12/30 - 16:03
Thank you, it solved that issue.
But my micro sd is still not recognize... It appairs in the memory menu with 0b.
And internal storage is 13gb it should be 71 with my 64gb sd card.
Btw, i'll do a donation for your good work.
2014/12/30 - 16:08
Thank you very much!
Can you pls show me a screenshot of settings > storage (should work with 2 portrait pics)?
Kingess
Forum Posts: 11
2014/12/30 - 17:01
You should have receive it now, you're welcome ty to you for this great work.
Here's the screen
http://img11.hostingpics.net/pics/733044Screenshot20141230164719.pngImage Enlarger
2014/12/30 - 17:08
Unified storage looks good. All space available on the NAND in one partition.
Can you pls test a sdcard with less than 64 GB?
Kingess
Forum Posts: 11
2014/12/30 - 17:21
Heya again,
Tryed with a 2gb micro sd.
Exactly the same :/
2014/12/30 - 17:40
Hm, curious. I have a P9 on loan basis here and mounts are working.
Can you pls check the sdcard on the PC if it is error free?
v1.1_storage.pngImage Enlarger
Kingess
Forum Posts: 11
2014/12/30 - 18:29
Well, the cards are working perfectly on my galaxy s5 ans my PC..   :(
What should I do ?
2014/12/30 - 18:34
Do a clean install incl. eraseIDB.
Kingess
Forum Posts: 11
2015/01/07 - 18:03
Hello Oma, I'm back.
So, erase db. You mean just reinstall the rom ? Thanks
2015/01/07 - 19:19
Yes.
qasdff15
2015/01/08 - 19:17
Hey Oma,
is it just me or is it a bug that widgets are not working with stock and nova launcher?
I'm only able to create shortcuts instead of widgets.
jed57x
2015/02/10 - 17:34
Hi OMA
Realy nice rom, feels very fast and responsive! Tried it a little and no issues at all.
Love the unified storage. Would be nice have the cam working for take that for my daily driver. Can we espect any updates in the future?
Can you upload de parameter for other roms and make the storage unified?
PD: how can I remove the signal icon in the status bar?
81 Guest(s)
Devices in use: Desktop (73), Phone (8)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
