Gents,
OmniROM has landed on Teclast P90HD
P90HD by CrewRKTablets build v1.0
– stock recovery 4.4.0
– kernel york #854
– unified internal storage
– multi-user
– init.d support
– Dateimanager HD (Root)
– Nova LauncherÂ
build runs on any KitKat kernel:
kernel archive (just change kernel & resource in folder rockdev/Images)
Confirmed installations on:
iFive Air
how multi-windows works
not working:
- hwcomposer
- cam
hints:
...use Nova launcher and set animation/scroll to "faster than light" and
...enable Entropy Fixer with value 256
Special thanks to netlars !
– Oma -
2014/12/12
I have try this rom on pipo P4 wifi with kernel 665(riley rom) , i found some bug like orentation error and some time deep sleep for long time or S.O.D sleep of death , and if use default partition omni rom i lost internal data , then i choose default pipo partition
The kernel is already in the archive (Wifi and 3G tabs have a common kernel): http://crewrktablets.arctablet.com/?wpfb_dl=2223
The build has an unified internal storage. Do not use other partition layout as this will cause problems.
To correct orientation just edit build.prop:
ro.sf.fakerotation=false
ro.sf.hwrotation=0
Use the included File Manager HD. Goto settings and enable Root Explorer and system /rw. Then navigate to /system/build.prop.
Enr1988 said
Hi Oman, this build will work on Pipo P1 wifi? If yes, how to flash?
Yes, it will. Here is the latetest kernel: http://crewrktablets.arctablet.com/?wpfb_dl=2217
Change kernel and resource in folder rockdev/Images before flash.
2014/08/10
HEY! OMA, Â I downloaded this rom to my p90hd but now it is stuck at the splash screen and before then i had trouble with the rom crashing in the play store. cfor some reason i can not get the tab to go into bootloader. I have flashed my p90hd with all your moded roms and they all work but this one.
Hard power off (press Power until screen goes black). Then press Power and Vol+ until AndroidTool shows "Found". Then LowerFormat before Run.
2014/12/18
Hi, wonderful rom, working very fast but somes issues :
My micro sd card is not recognize (Lexar 64gb working with oma's roms) Â
When the tablet is locked, she never stop to restart...Â
I also got the issue for the play store with a lot of force close...
I go back on oma 1.5 and I wait for an update. Ty.Â
Well, had a build v1.1 ready on 23. Dec with working hwcomposer and CWM/TWRP.
Sadly my P90HD died due to unknown hardware failure.
Unfortunately donations here are not on a level that after paying the server costs much money is left to buy hardware.
Anyway, I can upload something and it's up to you guys to test.
Ok, I will upload it later this evening.
Usually we try to do our builds as most generic as we can.
If all guys which gains help here would donate a buck we could support more tabs faster.
However, this here is hobby. Just an antipol to real life
Do not think too much on it. Let's have fun!
54 Guest(s)
Devices in use: Desktop (47), Phone (7)
