I am running out of idea's now .... last try: http://crewrktablets.arctablet.com/?wpfb_dl=2369
Ok, let's test with build v2.1: http://crewrktablets.arctablet.com/?wpfb_dl=1978
Do a clean install with the a6k7 kernel.
Install CWM and this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2386
Great news
2015/01/09
Oma Hi,
4.4.2 version experiences very slow wifi after deep sleep so i went back to 4.4.4. Firstly i flashed your omni 4.4.4 version and then went back to 4.4.4 multi-window.
In regards with the camera not working i got the boot log using adb and i found that from omni version libisp_silicomimageisp_api.so was missing so i copied it to the lib folder and gave correct permissions but i got the following error
E/HAL ( 150): load: module=/system/lib/hw/camera.rk30board.so
E/HAL ( 150): dlopen failed: cannot locate symbol "_ZN8SkBitmap9setConfigENS_6ConfigEiij" referenced by "camera.rk3
0board.so"...
I then flashed your 4.4.4 multi-window build and applied the camera fix for a6k7 and the error is exactly the same as above cannot locate symbol. Using the readelf -a command in linux i found this is referenced in libisp_silicomimageisp_api.so and all the needed libraries are there, i dont know if you have any idea how to fix this.
On another note after flashing the Omni rom from that point on brightness adjustment is not working in the 4.4.4 multiwindow build.
Looking forward to your expert opinion.
Doesn't work with 4.4.4. Use v2.1, which is 4.4.2.
98 Guest(s)
Devices in use: Desktop (87), Phone (10), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
