2015/01/09
Hi Oma,
Great rom thanks. One minor issue i am facing is that wireless is a bit slow sometimes especially after deep sleep. On same network other devices are fine and is only sorted once i restart the tablet.Â
Also i wanted to ask whether there are plans for a 4.4.4 build. I tried the one for a6k6 with multiwindow but back camera is not working,
Install the Multi-Window build and additionally the CWM (see post 17): http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rom-teclast-p90hd-4-4-4-custom-root-firmware-20140809/
Boot into CWM and install this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2369
2015/01/09
Hi Oma,
Thanks for the info. I installed multi window and CWM on my A6K7 but i cannot boot into recovery neither using power and vol+ or reboot menu. it is just black screen. Tried CWM from both your latest tool at [ RK3288 ROM ] TWRP/CWM Flash-Tool custom root firmware (2015/01/03) and from this post.
Hm, I don't know what the A6K7 kernel is doing. Flash the CWM from the TWRP/CWM Flash-Tool. When you see the black screen pls press Power for 2 sec to see if the kernel is booting.
2015/01/09
Hi Oma,
Tried what you mention above but nothing is shown after pressing power button for 2 seconds. all i can do is hold power to switch off and then power on the tablet. Can 't get in CWM recovery. I also thought of maybe getting logs using adb but adb cannot see the tablet. ADB can see my other android devices is there any special way to connect this tablet to the pc using adb?
Unplug all cable. Press vol+ and power until you see the kernel logo.
2015/01/09
Hi Oma,
Still nothing.no kernel logo all i see even when i boot the tablet is teclast for a split second and then the boot animation. What kernel logo are you referring to? The same applies when using the 4.4.2 rom. Currently i am on 4.4.4 multiwindow and kernel 854. Is there any other way i can apply the camera fix?Â
Yes.
87 Guest(s)
Devices in use: Desktop (76), Phone (10), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
