[ RK3288 ROM ] Teclast P90HD 4.4.2 custom root firmware (2014/10/14)
This is only for the new hardware revision A6K7.
2014/11/14 - 21:28
Gents,
This is only for the new hardware revision A6K7 ;-)
P90HD A6K7 by Oma build v1.0  (based on stock v1.04)
Update 31.12.2014:
- fix broken contacts provider
- some minor corrections
- CWM 6.0.5.1 included
P90HD A6K7 by Oma build v1.1
– stock recovery 4.4.0
– kernel york #822, preempt 21. Oct 2014
– CrewRKTablets recovery CWM 6.0.5.1 [v1.1]
– 4 GB internal storage
– init.d support
– Dateimanager HD (Root)
– Nova Launcher
Hints:
– start with Nova Launcher to enable proper contacts services!
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
V1.0_02.pngImage Enlarger
 V1.0_01.jpgImage Enlarger
 V1.0_03.pngImage Enlarger
 V1.0_04.pngImage Enlarger
CWM_CrewRKTablets_v1.1_2-4.jpgImage Enlarger
jed57x
2014/12/15 - 17:41
What changes is the revision of hardware?
2014/12/15 - 17:54
Confirmed is a new cam. Maybe more ... not much feedback on that until now.
renton82
2014/12/30 - 12:46
Just flashed this rom, all is ok, but i can reach 33k point on antutu, how can i obtain 40k ? I saw that cpu is limited to 1,6Ghz is it normal?
2014/12/30 - 14:05
Yes, CPU is limited by the kernel to 1,6 GHz. Above hardware will be instable.
Advertisings show 40k in Antutu 4.5. With 5.x scoring has been changed several times. 33k in Antutu 5.5 is ok.
renton82
renton82
2014/12/30 - 15:47
Ok, thank you very much!
renton82
2014/12/30 - 17:36
I have another question: why google contacts app is missing? I can't install it anymore...
2014/12/30 - 18:27
Attached the app. Unzip and install it via File-Manager.
renton82
2014/12/30 - 19:32
I have done it, but contacts don't sync with google accounts
2014/12/30 - 20:12
Goto settings > Google Account and try sync manually. If no success remove account and it set-up again.
renton82
2014/12/30 - 20:24
Nothing to do, it doesn't work...
2014/12/30 - 20:37
Open the included File-Manager HD. Goto settings and enable Root Exploer and Change System Folders.
Navigate to /system/priv-app and delete Contacts.apk.
renton82
2014/12/30 - 21:15
Nothing, if i delete it, contacts app disappear...
2014/12/30 - 21:20
Then you may have not installed the other one. Anyway, copy that one to /system/priv-app.
renton82
2014/12/30 - 22:17
Nothing... Even if i try to add a contact i can't add in google account, only in local...
Currently Online: Azabatxe1
141 Guest(s)
Devices in use: Desktop (137), Phone (5)
jacksonrid
usdown
ibob64
