[ RK3288 ROM ] Pipo P9 / P4 CM12.1 custom root firmware (2015/10/08)
paparazzo_1
Forum Posts: 55
Thanks Received: 4
106
2016/01/02 - 07:39
Nice found! Seems we have luck and the Pipo P7 kernel recognizes the code also.
Can you pls upload your qwerty.kl (system/usr/keylayout/qwerty.kl). I shall do a fix for Pipo P7.
Hi, Oma!
No. You just need remove line key 158 BACK from following files - generic.kl, qwerty.kl, rk29-keypad.kl
Otherwise volume up hardware button will cause doublespeed of volume increase, if we left 115 and 158 buttons as VOLUME_UP sametime.
I have Pipo P7 and fixed volume up button.
ANd please make GPS fix for Pipo P7 Lollipop.
107
2016/01/02 - 08:39
Ok, here is a fix for the P7 key issue: http://crewrktablets.arctablet.com/?wpfb_dl=2780
Is GPS working with the build from this thread?
ArikaSalaf
108
2016/01/04 - 13:34
a.pngImage Enlargerb.pngImage Enlarger
Hi Oma just play with overclockmatic then i this is result
Are this real or fake......?
Pipo P4 FHD display dpi set 220, OC kernel  Cpu 1920, GPU 625, DDR 600
c.pngImage Enlarger
ivia
109
2016/01/04 - 13:43
Hi all,
Any word about GSM-3G? I've this release of P9 and would like to know if it works ok?
BR
Bernard75
Forum Posts: 13
110
2016/01/27 - 14:29
Hi Oma.
 Pipo 9 with kernel #69.
Impossible to use USB OTG with USB memory (cable and key working with other devices)
Any suggestion ?
Thank you again for your ROM.
Bernard
Currently Online: 5256makc
114 Guest(s)
Devices in use: Desktop (110), Phone (5)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
