[ RK3288 ROM ] Pipo P9 / P4 CM12.1 custom root firmware (2015/10/08)
91
2015/12/18 - 09:42
Yes, one can do a backup of the build when using TWRP/CWM. Just reboot to recovery and choose Backup.
Due to difference of the partition layout between KK and LP it is necessary to re-flash the build first and then do the Restore of the backup.
If TWRP/CWM is not incoluded in the KK build, you will find it here: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-twrpcwm-flash-tool-custom-root-firmware-20150117/?lang=fr
hawkdown77
92
2015/12/18 - 17:16
Omã,
Which partitions in twrp i need check to do a nandroid backup in pipo p4 KK?
Bjorg
93
2015/12/18 - 22:22
Hi Oma,
i've tried 3 roms now but they all stick on boot screen, been at it now for 6 hours and even the pipo P9 3G stock rom (20141218_PIPO_P9_update_OTA_3G_#214) from the original site keeps on the boot screen.
With the this rom i can atleast enter TWRP but i can't mount my ext_sd or usb_otg so i cannot install the camera fix below.
Can you include the fix in the rom so i don't have to add it in twrp?
if your P9 doesn't boot up you most likely have a hardware revision
with another camera lens - pls install model fix via TWRP
btw, the ext sd and usb_tgo work on my gf's samsung without any problems.
thanks in advance.
BR,
Bjorg
94
2015/12/19 - 10:05
Make sure the scdard is FAT32 formatted and put it in before booting in TWRP.
95
2015/12/19 - 10:06
All which are not 0 MB.
Bjorg
96
2015/12/19 - 17:06
That worked, now it starts into android but it asks for a pw.
when i enter something then it wants to factory reset and reboot, but after the reboot it keeps displaying the teamwin logo without entering it.
any suggestions?
97
2015/12/19 - 17:13
The build is not installed properly. Flash again incl. LowerFormat.
Bjorg
98
2015/12/20 - 02:28
it works now, thanks for the help 🙂
Best regards,
Bjorg
99
2015/12/31 - 11:31
New Pipo P9 kernel #69 preempt 30 Dec 2015: http://crewrktablets.arctablet.com/?wpfb_dl=2778
Battery stats looks a bit better now, however still not perfect.
v1.1_60.pngImage Enlarger
v1.1_61.pngImage Enlargerv1.1_61a.pngImage Enlargerv1.1_62.pngImage Enlargerv1.1_63.pngImage Enlarger
jonasstr
jastaz23
Forum Posts: 28
100
2015/12/31 - 12:13
How about P4 sir? Battery is nuts shutsdown at 30+% sometimes, drops quickly to 84% in minutes from 100% full charge...
Happy new year!
jonasstr
Forum Posts: 35
101
2015/12/31 - 12:20
I've two little "problems" both on p7 and p9:
- Bluetooth activates itself. I don't know the pattern yet, but it exists and is reproducable.
- Connecting the charger boots the device up
Btw: I "fixed" the volume button issue for the p7. Just download ButtonRemapper (http://forum.xda-developers.com/showthread.php?t=850464) and set button no 115 and 158 to Volume Up. Thats it.
The following users say thank you to jonasstr for this useful post:
102
2015/12/31 - 15:34
Nice found! Seems we have luck and the Pipo P7 kernel recognizes the code also.
Can you pls upload your qwerty.kl (system/usr/keylayout/qwerty.kl). I shall do a fix for Pipo P7.
For Pipo P9: BT active by default is here only noticed when first boot up. Reboot when charger gets connected is here not reproducable. Pls upload kmsg and last_kmsg logs.
103
2015/12/31 - 15:42
Pipo P4 has the same PMU. Issue is descriped in post #28.
Other manufaturers are able to use the right driver/table in their kernel. Attached an example of IFive Air (same PMU).
v1.1_03-1.pngImage Enlarger
jonasstr
Forum Posts: 35
104
2015/12/31 - 16:46
I will send you the qwerty-file asap, kind of busy preparing for new years eve.
The "issue" isn't acutally related to the device rebooting:
When powered off an android device connected to a power device usually gets into some charger-screen or black screen. Until you power it in. In my case the device just starts up - making it impossible to charge an unpowered device.
105
2015/12/31 - 16:53
Ah, that is what you mean. "Normally" the kernel reboots in charger mode. This is not longer enabled. They call this "always on strategy", which means you can only power off the tab when no cable is plugged.
87 Guest(s)
Devices in use: Desktop (54), Phone (32), Tablet (1)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
