[ RK3288 ROM ] Pipo P9 / P4 CM12.1 custom root firmware (2015/10/08)
76
2015/12/12 - 18:44
Works fine here. Maybe you need to switch between AwesomePlayer and NuPlayer in Developer options.
v1.1_44.pngImage Enlargerv1.1_45.jpgImage Enlarger
KenMic35
KenMic35
Forum Posts: 54
77
2015/12/12 - 18:48
i tried to switch between AwesomePlayer and NuPlayer videos won`t play and without sound too
78
2015/12/13 - 09:24
I am terrible sorry Ken, but I cannot imagine why it doesn't work on your P9. On my P9 here everything works pretty well.
KenMic35
Forum Posts: 54
79
2015/12/13 - 09:27
back to riley rom 1.9.... fast and damn good!
keteden666
80
2015/12/14 - 11:25
Hi Oma, the netflix app didn´t work, it is the only problem I have found in this rom
The following users say thank you to keteden666 for this useful post:
hawkdown77
81
2015/12/14 - 18:32
Thank you for feedback! Did you try the app from post #73? If so what is exactly the issue? Maybe you can provide a logcat log?
bloodgnome
Forum Posts: 11
Thanks Received: 4
82
2015/12/15 - 01:05
I was using this rom without problems for a while now. But now i can't install anything. I always get app not installed. I have enough space and installing apps via playstore work fine but everything else don't. What could that be?
83
2015/12/15 - 06:37
You are on P4, right? Can you pls post screenshots of settings/storage (full lenght)?
hawkdown77
84
2015/12/15 - 19:32
My netflix didnt work too.
Why??
It stay loading screen and movie doesnt show.
bloodgnome
Forum Posts: 11
Thanks Received: 4
85
2015/12/15 - 19:46
- Oma
Yes P4. After a couple more tests it seems that some apps can be sideloaded but games can't.
Really strange. Here are some pictures:
tmp_7410-Screenshot_2015-12-15-19-45-501231015317.pngImage Enlarger
tmp_7410-Screenshot_2015-12-15-19-24-29-2081095160.pngImage Enlarger
bloodgnome
Forum Posts: 11
Thanks Received: 4
86
2015/12/15 - 20:18
I think i have found out something. If there is a lib folder inside the apk it wont install. Apks without lib folder install just fine.
bloodgnome
Forum Posts: 11
Thanks Received: 4
87
2015/12/16 - 09:09
Fixed my Problem with Apps cound't install:
Using Luckypatcher I deleted all the Odex Files. Now everything works fine *yay.
88
2015/12/17 - 19:47
Ok, tried to compile the engine. Install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2765
Pls check Netflix with the app from post #73.
v1.1_46-1.pngImage Enlargerv1.1_47-1.pngImage Enlarger
89
2015/12/17 - 20:31
Nearly all codecs are available by switching between "old" and "new" standard Player 😉
v1.1_48.pngImage Enlargerv1.1_49.pngImage Enlarger
hawkdown77
90
2015/12/17 - 23:48
Hi Omã. Thanks for help,
But i downgrade to 4.4.4 and now netflix works good again.
Can i do a nandroid backup in pipo p4 in this 4.4.4 if case i need a backup? If yes how i do?
I would like to install 5.1.1 to test your modifications for netflix.
Thanks for support.
75 Guest(s)
Devices in use: Desktop (65), Phone (10)
swan12
heftpflaster
