[ RK3288 ROM ] Pipo P9 / P4 CM12.1 custom root firmware (2015/10/08)
jonasstr
Forum Posts: 35
61
2015/12/03 - 14:45
glotzi said
jonasstr said
jonasstr said
I tried the newer Lollipop Build 1.1.7: Same result as with CM: Bootanimation - Reboot...
Besides: By any chance is there a working kernel for the p7?
Something to test for you 😉
I guess there are some P9 in the field which have a different camera lens, which is the root cause for the reboot. Pls check this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2737
Works perfectly with your camera fix!!
Thank you so much!
Jonas
@Jonas: Your P9 is working now?
P7 works with the problems documented above, P9 works beautifully, i think, with gps/camera etc. working. Didn't try facebook yet book would guess I'd have the same error there.
glotzi
62
2015/12/03 - 22:42
Ok, the P9 CM 12.1 works for me too now with the camera fix.
Thx Oma.
63
2015/12/04 - 18:20
Thanks for feedback! Update post #1 with different model fixes.
64
2015/12/04 - 21:07
Can somebody test the attached facebook app? Do not update.
calestrom
calestrom
Forum Posts: 30
65
2015/12/08 - 18:38
Thanks Oma,
Now that I got it to boot (Pipo P9 3G), it's ready for testing... So far really good.
Working:
- Both cameras
- Got 2D fix from GPS (after few minutes). It seems like GPS is working
- BT audio!
Not working
- some Wmv videos doesn't work, but it's okay. Maybe it's weird encoding
I'll update later of the progress, now I'm really happy!!! CM on Pipo looks really good and snappy. Thanks again Oma!
66
2015/12/08 - 21:39
Fine. You should be able to play wmv codecs by disabeling AwesomePlayer in Developer options.
jonasstr
Forum Posts: 35
67
2015/12/09 - 11:33
On P7: Installed, logged in, updated. Works fine, thank you!
Other P7 Problems:
- With Xposed/Gravitybox its not possible to edit navigation bar or status bar
- Vol+ increases volume, but: its also "esc" - it has no hardware-"esc", only the one in the nav-bar. Is it possible to disable that one?
jonasstr
Forum Posts: 35
68
2015/12/09 - 15:18
And a feedback for the p9:
Since it has no hardware volume-buttons we need them in the navigation-bar. Without it's hard to change volume.. I see you have an extra volume-button on the left. How do I get that one?
calestrom
Forum Posts: 30
69
2015/12/09 - 15:29
That icon must Virtual Volume Button
https://play.google.com/store/apps/details?id=it.claudio.chimera.virtualvolume&source=labnol
I would prefer volume button on navigation, since I keep my installed software minimum.
keteden666
70
2015/12/09 - 23:36
Do you use NETFLIX? It doen´t work properly. In fact, it gets stuck on the loading screen, even though I'd already installed xposed and Netflix fix module. Any way to make it work perfectly?
KenMic35
Forum Posts: 54
71
2015/12/11 - 08:03
there are other P9 lollipop rom`s in here, is this the best one yet?
Does facebook app work?
kallesone
Forum Posts: 46
Thanks Received: 7
72
2015/12/11 - 14:51
Hi Oma and co.
This is the latest beta from pipo for the p9.Date on 01/12/2015.
I hope its useful.
http://www.mediafire.com/download/c3mk5luu2bqpg5u/rk3288_sdk4.4_p9-EPOINT_20151201_%23278.rar
Regards.
73
2015/12/12 - 17:12
By careful with the builds for epoint, the hardware seems to be different.
The patched facebook app was confirmed working (see post #67).
Here is a patched Netfix app which might work. I cannot test that, but I can confirm maxdome is working fine out of the box (so no DRM issue).
v1.1_40.jpgImage Enlarger
v1.1_41.jpgImage Enlarger
74
2015/12/12 - 17:44
Kodi works fine, too 😉
v1.1_42-1.jpgImage Enlargerv1.1_43-1.jpgImage Enlarger
KenMic35
Forum Posts: 54
75
2015/12/12 - 18:19
reflashed this rom and facebook app works fine when downloaded from the play store but sadly videos don`t play on facebook and instagram!
oma can you help me fix this issue pls?
71 Guest(s)
2 Guest(s)
Devices in use: Desktop (66), Phone (5)
swan12
heftpflaster
