[ RK3288 ROM ] Pipo P9 / P4 CM12.1 custom root firmware (2015/10/08)
46
2015/12/01 - 20:16
4thjak said
Rotate problem, when an app opens on portrait mode, the screen is stuck.
Though Xposed is not working yet.
BTW, will the unified parameter work on this V1.0 LP rom of yours?
Can you link me one or two apps for testing?
Xposed will not work on the customized RK framework.
An unified storage needs to be defined in the framework. So, it is not just the partition layout.
4thjak
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
47
2015/12/02 - 03:28
Here's the app that I use, forces the tab to go portrait mode in CM 12.1 rom:
power clean, https://play.google.com/store/apps/details?id=com.lionmobi.powerclean
shutup, https://play.google.com/store/apps/details?id=com.yirga.shutapp
Power clean is my alternative to clean master, since clean master makes the touch crazy in the two LP roms I've used. I use this apps also during my KK days.
Thanks sir... hope this helps.
Pipo M8pro
Pipo M9pro
Pipo P4
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
48
2015/12/02 - 08:35
If I may ask this also sir Oma, why is it that your first LP rom's UI is very smooth while the CM12.1 stutters in its stock and even in a nova launcher?
Pipo M8pro
Pipo M9pro
Pipo P4
jonasstr
Forum Posts: 35
49
2015/12/02 - 20:59
Found a P7 kernel which may works: http://crewrktablets.arctablet.com/?wpfb_dl=2738. Pls check with the CM12.1 build and report back.
 Good evening,
Just wanted to try. So far, just replacing resource/kernel and the recovery, i'm stuck in a bootloop. I guess the p9s parameters file is wrong for the p7, since theres an error formatting data, not just internal_sd, in twrp
50
2015/12/02 - 21:13
Change this parameter file in folder rockdev and flash again incl. LowerFormat: http://crewrktablets.arctablet.com/?wpfb_dl=2724
51
2015/12/02 - 21:30
Sorry, but cannot simulate this effect here on my machine. Power Clean app also works fine (the UI turns back).
v1.1_37.jpgImage Enlarger
jonasstr
Forum Posts: 35
52
2015/12/02 - 21:46
Done that. Now /data can be formatted, but sadly the bootloop-phenomenon occurs - same problem a on the p9 perhaps.
jonasstr
Forum Posts: 35
54
2015/12/02 - 23:21
Install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2739
still looping.
jonasstr
Forum Posts: 35
55
2015/12/02 - 23:34
jonasstr said
still looping.
And again with the P7:
Oma_RK32_P9_LP_5.1.1_v1.0a works, instead of all the others.
jonasstr
Forum Posts: 35
57
2015/12/03 - 10:26
Well! P7 starts up with the latest patch applied.
At first look:
- With DPI set to 180ppi, its looking very good.
- Performance is good, some animations a little bit shuttery
- CM Camera App gets killed
- - Google Camera works, LED works, gets killed when entering settings
- - OpenCamera works
- No GPS
- Could remove all sim-related options (sms/mms, phone, sim-settings)
jonasstr
Forum Posts: 35
58
2015/12/03 - 10:48
Thank you for detailed feedback. Facebook should work when installed as system app. HDMI works for me @1080p. Maybe you need to switch between resolutions before it shows up. However, screen zoom doesn't work, which is a kernel issue.
Made Facebook a system app, but behaviour stays the same: takes a long time to get ready, login takes a long time too, just to get back to the login screen. Deleted cache after making it a system app.
jonasstr
Forum Posts: 35
59
2015/12/03 - 14:12
jonasstr said
I tried the newer Lollipop Build 1.1.7: Same result as with CM: Bootanimation - Reboot...
Besides: By any chance is there a working kernel for the p7?
Something to test for you 😉
I guess there are some P9 in the field which have a different camera lens, which is the root cause for the reboot. Pls check this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2737
Works perfectly with your camera fix!!
Thank you so much!
Jonas
glotzi
60
2015/12/03 - 14:42
Thank you so much!
Jonas
@Jonas: Your P9 is working now?
107 Guest(s)
Devices in use: Desktop (103), Phone (4)
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
mantonero
