[ RK3288 ROM ] Pipo P9 / P4 CM12.1 custom root firmware (2015/10/08)
jonasstr
Forum Posts: 35
31
2015/11/22 - 19:14
Nope.
32
2015/11/22 - 19:16
Ok, there are changes on gralloc. Pls try build v1.1 with this fix (install via TWRP): http://crewrktablets.arctablet.com/?wpfb_dl=2730
jonasstr
Forum Posts: 35
33
2015/11/22 - 19:26
-- Installed Your LP1.1 via AndroidTool (including lower format).
-- Ended bootlooping with Esc+Power
-- Flashed TWRP via AndroidTool
-- Installed your gralloc Patch via TWRP and formatted dalvik&cache
Result: Bootloop again.
34
2015/11/22 - 19:46
Last try. Download again: http://crewrktablets.arctablet.com/?wpfb_dl=2730
jonasstr
Forum Posts: 35
35
2015/11/22 - 20:00
Same result with that one. Thank you for all your hard word. I think we wont find out what differs for my tab.
jastaz23
Forum Posts: 28
36
2015/11/24 - 00:01
Tested this CM 12.1 for P4 (and P9) it works well, though still has some issues with auto brightness like the Pipo 5.1.1 rom but the hdmi function doesnt work well, it just shows garbled image on the ext. monitor. The hdmi output from Pipo 5.1.1 rom doesn't do this but there is a problem with screen zooming...
My test so far..
*Xposed works perfectly (I used the recent xposed v75-sdk22-arm.zip from xda with xposed installer 3.0_alpha4 apk)
*CM themes works perfectly from wallpapers to fonts to boot animation etc. (even my facebook app was themed by     one of themes from Playstore)
*MX Player works with HW+decoder ( I use V1.8.0 nightly.20151120) non nightly builds of mx player have some issues  with cm roms..
*Facebook won't login if you use /download a fresh one from Playstore, you must use your back up file+data,  ex.  Facebook back-up +data from titanium)
*Camera output is still yelowish on dark environments ( the one from Pipo 5.1.1 was actually better), but it's not a big  deal since this is a tab...
*Some apps that force close on Pipo 5.1.1 rom works perfectly on CM 12.1 (for me it was OLX, Zalora etc.)
*Some games from playstore which says incompatible with your device on Pipo 5.1.1  can now be installed
*Issues with some apps not installing (*app is not installed error) from either Playstore, your Back-up and downloaded apks can be fix by installing Terminal Emulator and entering the following  commands...
su (press enter)
pm set-install-location 1 (press enter and it's done)
that's all from my test with cm 12.1, still testing for more , I'm keeping this rom for now on my P4, will have to use the tv box player for animes and movies for the moment, hopefully you guys can fix the HDMI issues.
Thanks OMA and crew for all your hardwork for these devices!
37
2015/11/25 - 18:20
Thank you for detailed feedback. Facebook should work when installed as system app. HDMI works for me @1080p. Maybe you need to switch between resolutions before it shows up. However, screen zoom doesn't work, which is a kernel issue.
v1.1_38.jpgImage Enlarger
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
38
2015/11/26 - 01:19
On my P4,
Flashed this, changing kernel, resource and parameter as instructed.
Touch is unusable, and it's asking for a password.
So I flashed kernel, using the first of sir Oma's LP rom for the P4, touch is all well, but it still asks for the password and TWRP hangs in its startup.
Please tell me where have I gone wrong. Help! Cry
Pipo M8pro
Pipo M9pro
Pipo P4
jani
39
2015/11/26 - 14:20
40
2015/11/26 - 16:15
4thjak said
On my P4,
Image is not properly on the eMMC. Try again incl. LowerFormat.
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
41
2015/11/26 - 17:23
wow thanks sir Oma.
I downloaded manually kernel/resource and parameter at Crew Rktablets, I can't get pass pipo logo. At Twrp as I do a factory reset it says failure, can't mount internal storage.
So now I did not wipe factory reset at TWRP, boots ok now and wow its nice... Thanks sir Oma for the love, you truly are magnificent.
Pipo M8pro
Pipo M9pro
Pipo P4
jonasstr
Forum Posts: 35
42
2015/11/27 - 12:48
4thjak said
wow thanks sir Oma.
So Your're on the p4 or the p9?
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
43
2015/11/27 - 16:18
Hi, I'm on a P4.
Here's some of the bugs I've found:
- Rotate problem, when an app opens on portrait mode, the screen is stuck, and when in screenlock mode and it goes to portrait, screen gets stuck to portrait. To free it from being stuck, you'll have to kill the app (ex. shutup, just use the widget).
- Clean Master makes the touch freeze
- Stuttering (a bit laggy) in ui browsing (I had to put settings in nova to faster than light, and in settings animation to .75x to achieve fluidity) and still it stutters a little. Pressing the recent apps, swiping down for the shortcuts menu... it stutters.
On Oma's first LP rom for the P4,
I have not twicked the tabs animation from settings to nova launcher settings, the UI is very smooth. And my problems with that rom is that xposed does not work, clean master freezes the screen, calendar app when editing, screen goes gltichy.
Any fix on this please?
Pipo M8pro
Pipo M9pro
Pipo P4
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
44
2015/12/01 - 04:09
Though I have solved the lag/stutter on the CM 12.1 by turning off most of the animation that lollipop delivers. Well that broke my heart a little, then what shoved me off the rom is the rotate problem, it really is getting stuck even in stock launcher with no apps yet, just a test on a power cleaner app and boom, portrait became stubborn.
Now I'm back with sir Oma's first LP rom for our beloved P4, UI is very fluid, and that's without touching the animation options. Though Xposed is not working yet, I'd be waiting on this LP rom V1.0 for the day Xposed framework becomes available for this lovely rom. One more bug was with Calendar LP themed app of google, the garbage screen glitch every time I edit or make a sched.
Thanks sir Oma...
BTW, will the unified parameter work on this V1.0 LP rom of yours?
Wishing for more improvement updates and magic to come before the year ends... Happy Holidays!
Pipo M8pro
Pipo M9pro
Pipo P4
45
2015/12/01 - 19:57
jonasstr said
I tried the newer Lollipop Build 1.1.7: Same result as with CM: Bootanimation - Reboot...
Besides: By any chance is there a working kernel for the p7?
Something to test for you 😉
I guess there are some P9 in the field which have a different camera lens, which is the root cause for the reboot. Pls check this fix: http://crewrktablets.arctablet.com/?wpfb_dl=2737
Found a P7 kernel which may works: http://crewrktablets.arctablet.com/?wpfb_dl=2738. Pls check with the CM12.1 build and report back.
Currently Online: 5256makc
125 Guest(s)
Devices in use: Desktop (121), Phone (5)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
