[ RK3288 ROM ] Pipo P9 / P4 CM12.1 custom root firmware (2015/10/08)
2015/11/21 - 16:43
No kernel for P7 and Pipo is still not publishing kernel sources.
Let me have some logs (option 1): http://forum.xda-developers.com/showthread.php?t=1944776
jonasstr
Forum Posts: 35
2015/11/21 - 17:37
Here are the logs for CrewRKTablets_RK32_P9_LP_5.1.1_v1.1 With Kernel #47:
2015/11/21 - 19:00
Pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2729
jonasstr
Forum Posts: 35
2015/11/21 - 19:21
Lower Format
Flashed CrewRKTablets_RK32_Pipo_P9_CM12.1_v1.1
Did Wipe Factory Reset.
Flashed over the fix.
Reboot to system
Result: Same. Boots up some seconds with the CM12 boot logo, then reboot.
jonasstr
Forum Posts: 35
2015/11/21 - 19:22
jonasstr said
Lower Format
Reboot to system
Or do I need to change the kernel there somehow too?
2015/11/21 - 19:47
I cannot really find a reason nor simulate here on my Pipo P9 why the latest builds (LP v1.1 and CM12.1 v1.1) crashes on your tab. Might be hardware driven. Sorry.
jonasstr
Forum Posts: 35
2015/11/21 - 21:15
Just realized it is the 32g 3g Version, not 16gb. Could that cause a problem combined with the Parameter file?
2015/11/21 - 21:48
Typically P9 has 32 GB. What is your eMMC size?
jonasstr
Forum Posts: 35
2015/11/22 - 13:59
I thought that perhaps the regular size is 16gb, since you let me flash CrewRKTablets_RK32_CM12.1_LP_5.1.1_parameter_16GB once.
2015/11/22 - 14:26
This was just to check parameters which could have an influence.
jonasstr
Forum Posts: 35
2015/11/22 - 18:31
Hi there,
Oma_RK32_P9_LP_5.1.1_v1.0a works. What changed since that?
Yours,
Jonas
2015/11/22 - 18:35
v1.0a comes with kernel #30. Does it also work on your tab with kernel #47?
2015/11/22 - 18:50
Just a word to the battery stats. The table in the kernel is crap. Battery voltage (yellow line) and battery stats (green line) do not have a linearity. High drain test scenario was: streaming video in Youtube app with sound via Bluetooth speaker. Build should be good for 7-8 hours usage.
streaming_video_bluetooth_audio.pngImage Enlarger7h_constant_drain.pngImage Enlargermissmatch_voltage_battery_stats.pngImage Enlarger4h_loading.pngImage Enlarger
jonasstr
Forum Posts: 35
2015/11/22 - 19:11
Suprisingly: It does.
2015/11/22 - 19:13
And build v1.1 (with kernel #47) will not boot on your tab?
180 Guest(s)
Devices in use: Desktop (170), Phone (10)
