CM12.1 has landed on Pipo P9 / P4 😉
CrewRKTablets RK32 P9 CM12.1 build v1.1
– CrewRKTablets recovery CWM 6.0.5.1
– sekernel #47 preempt 8 Sep 2015
– unified storage
– multi user
– stagefright patch
– Reboot Menue
instructions are included in the download pack
if your P9 doesn't boot up you most likely have a hardware revision
with another camera lens - pls install model fix via TWRP
for installation on Pipo P4 change:
- parameter file in folder /rockdev
- kernel/ressource in folder /rockdev/Image
for installation on Pipo P1 change:
for installation on Pipo P7 change:
- install model fix via TWRP
hints:
…use Nova launcher and set animation/scroll to “faster than light”
– Oma's favourite apps for LP
– Xposed framework test pack
Special thanks to mussonero !
KenMic35, admin, calestromPer aspera ad astra, we rock the Tablets !
2013/02/22
KenMic35 said
wow! CM12.1 for the pipo p9??
Does it really work? any bugs? is it slow/laggy?
where do you have been all this time? :)))
http://crewrktablets.arctablet.com/?p=5397
I´m with it since 1 and half months.
Use it with #47 kernel.
Problems,battery drain and little choppy.
P9 or P4? Build has unified storage, so there is no internal sdcard. Did you execute LowerFormat?
Curious. Try again.
2015/06/01
Thats what I did for some times now without changes:
- Flashed Riley Rom to verify the device is working (it does..)
- Switched to loader mode in AndroidTool (from the download in post #1)
- LowerFormat in AndroidTool
- Run in AndroidTool
- in TWRP chose wipe - factory reset
- reboot to system
- cyanogenmod bootscreen appears, takes some time and then goes back to the bootloader screen, cyanogen again etc etc
Can you pls verify with this parameter file (change it in folder rockdev)? http://crewrktablets.arctablet.com/?wpfb_dl=2724
2015/06/01
Can you pls verify with this parameter file (change it in folder rockdev)? http://crewrktablets.arctablet.com/?wpfb_dl=2724- Oma -
Same result with that parameter file.
jonasstr said
Just tried the same with CrewRKTablets_RK32_P9_LP_5.1.1_v1.1. That one works, I think, except of one thing: NO TOUCH!!
This is a very old build. We know there are two hardware revisions with different touch controller in the field. Use kernel #47 or try this build: http://crewrktablets.arctablet.com/?wpfb_dl=2720
2015/06/01
jonasstr said
Just tried the same with CrewRKTablets_RK32_P9_LP_5.1.1_v1.1. That one works, I think, except of one thing: NO TOUCH!!This is a very old build. We know there are two hardware revisions with different touch controller in the field. Use kernel #47 or try this build: http://crewrktablets.arctablet.com/?wpfb_dl=2720
I tried the newer Lollipop Build 1.1.7: Same result as with CM: Bootanimation - Reboot...
I tried older Lollipop Build 1.1 with kernel #47: Working fine with touch.
What can I do to debug this? I'd like a lot more to have CM12.1 on my tablet. Besides: By any chance is there a working kernel for the p7?
66 Guest(s)
Devices in use: Desktop (61), Phone (4), Tablet (1)
jenom
kfwacky
fer30
culo1
dfrt
PQNY
