Just playing around with multi-windows 😉
Oma RK32 P9 LP multi-windows build v1.1
Oma RK32 P9 LP multi-windows build v1.0a
– sekernel #47 preempt 8 Sep 2015
– multi-windows
– stagefright patch
– Reboot Menue
– Kodi 15.2-RC1
instructions are included in the download pack
if your P9 doesn't boot up you most likely have a hardware revision
with another camera lens - pls install model fix via TWRP
for installation on other tabs change
kernel/resource in folder rockdev/Image:
- Pipo P4 kernel #70
- Pipo P1 kernel #150
- Pipo P7 kernel #65
not working:
- rotation UI (it is not intended to rotate the UI)
hints:
…use Nova launcher and set animation/scroll to “faster than light”
– Oma's favourite apps for LP
Did you execute LowerFormat? The stock recovery will format the partitons per default.
2015/11/28
Did you execute LowerFormat? The stock recovery will format the partitons per default.- Oma -
Yes, I used lower format in Android tool.
It said that 100% successfull Lower Format.
Also after flash automatically runs wipe - format data, cache, internal flash.
But after boot I got bootloop
There are different hardware revisions of the P9 in the field.
Did you try a LP build before? If yes, which one is working on your specific P9?
2015/11/28
There are different hardware revisions of the P9 in the field.Did you try a LP build before? If yes, which one is working on your specific P9?
Hi, Oma!
Yes I guess also than have other hardware revision.
Really for now from all firmwares (including RileyROM, officials and yours) only both works
1. Kitkat version 25.06.2015. I backuped it from my P9 when bought it.
2. Lollipop image called "P9_5.1.1_ROOT151002.img", downloaded from Chinese site.
They both works fine, all functions works. Lollipop also have working flashlight and correct camera flash
Yes, there might be a few tabs out with different cam sensor which kills the scenario. Having analized this firmware a few times now, but no idea of how to deal with that. Sorry.
Ok, I guess a different camera lens will kill the scenario.
<SensorName name="OV8858" ></SensorName>
<SensorLens name="LG-9569A2"></SensorLens>
Pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2737
No, GPS is not implemented. If you need GPS pls use the CM12.1 build.
Here is a GPS fix: http://crewrktablets.arctablet.com/?wpfb_dl=2769
135 Guest(s)
Devices in use: Desktop (125), Phone (10)
neozone2007@gmail.com
lux_man
davilima
adf
sebb
azqswx
Topics: 6026
Members: 261169
