2016/04/14
the first one (6m): boot loop
the other two (7l & 8l): went straight to recovery but no touch screen
When I say I have an early hardware version, it's because I bought the tablet (came direct from China) around Dec/Jan 2014/15. I didn't think the P9 had been out long before then, but I've never actually checked.
Ian
So does it have also Goodix touch?
Next try: http://crewrktablets.arctablet.com/?wpfb_dl=3016
2016/04/14
So does it have also Goodix touch?Next try: http://crewrktablets.arctablet.com/?wpfb_dl=3016
- Oma -Â Â
that one boot-loops
Ok, next one: http://crewrktablets.arctablet.com/?wpfb_dl=3017
Flash only kernel/resource like shown in the attachment.
No, just Run. Lower Format will wipe the partition layout.
Yes, there is no touch driver in that kernel 🙂
So the bad guy is the goodix touch driver itself. Strange.
Pls do some logs in TWRP. PC-Tool is here: https://forum.xda-developers.com/showthread.php?t=1944776
The download links are at the end of post #1.
If the tool works pls flash this one: http://crewrktablets.arctablet.com/?wpfb_dl=3018
59 Guest(s)
Devices in use: Desktop (54), Phone (5)
jacksonrid
