[ RK3288 ROM ] Pipo P9 LineAgeOS 14.1 custom root firmware (2017/01/01)
Maestro88
Forum Posts: 79
466
2017/12/13 - 17:05
Dear Oma! Master!
If you're alive, please upgrade to PIPO P9 Ilneage OS 15.
https://www.lineageos.org/Changelog-15/
On you last hope the master!
The following users say thank you to Maestro88 for this useful post:
raptyk
Hodgy
Advanced Member
Forum Posts: 154
Thanks Received: 8
467
2017/12/20 - 08:21
Has anyone tried replacing the screen on Pipo P9? My dead band of pixels across the top is growing, so I bought a new screen. However, the only guide I can find to replace the screen is for Pipo M9 - they've done it differently with the P9. Anyone know of a good how-to guide?
Ian
raxnaz
Forum Posts: 20
468
2018/01/04 - 17:22
Hi Oma,
I have been facing a bug when charging my P4, as it takes so much time for it, or sometimes it doesn't even charge!!! At the begining I thought it was my tablet's battery, but after downgrading to Oma's MM rom I realised it is this rom's problem.
Could you take a look to it, please?
Right now I don't have this rom installed so I cannot get any logs.
-wall-
469
2018/01/16 - 22:49
kallesone said
Oma pls,i have a big problem,my dc port has been broken,and i´m not capable to charge the tablet by usb port.
I have tried it at least with 10 different chargers,with different voltages and amp. too.But the tablet don´t charge.The red light shine for a second and then it goes off,(but the battery icon shows a thunder).
Same problem.
Hodgy
Advanced Member
Forum Posts: 154
Thanks Received: 8
470
2018/01/18 - 04:37
Is there any way we can get the latest security updates for this ROM?
Djuganight
Portugal
Forum Posts: 98
471
2018/03/25 - 17:12
Ian
Have the same issue.
I have "dead" band on top which makes touching the tablet an absolute nightmare as I need to keep rotating it in order to aknowledge the touches.
Where did you bought the screen and did you replace it?
Pipo P9
Hodgy
Advanced Member
Forum Posts: 154
Thanks Received: 8
472
2018/03/28 - 05:28
I bought it on AliExpress: https://www.aliexpress.com/item/New-10-1-Tablet-For-PIPO-P9-Touch-screen-digitizer-panel-replacement-glass-Sensor-Free-Shipping/32796261435.html?spm=a2g0s.9042311.0.0.i2AeEI
It was actually quite easy to replace, just have to be very very careful and gentle. Actualy, I need to open it up and clean again because I have dust trapped underneath. If I do it soon, I'll take photos and show you. With the new screen it feels like a new tablet again. I previously had some problems just using the soft keyboard, but that has now also been solved with the new screen.
josemlds
473
2018/04/12 - 17:16
hello
the GPS in my P9 with LineAgeOS 14.1 d'ont work.
solution???
Dave5322
474
2018/04/16 - 22:28
josemlds said
hello
solution???
The GPS is working with LineAgeOS 14.1 but I find it to be very weak, try it outside with the location setting at high accuracy.
I can not get any signal indoors.
jorm
Iceland
Forum Posts: 16
475
2018/04/26 - 22:08
Hi
What could be the reason for i get error when downloading from play store (error 960 and some other numbers as well) i have tried all the standard procedure clear cache and so on. i tried both 14,1 and as well the cm version
best regards
Jens
strjaz
476
2018/09/07 - 12:57
Hello. I need a lens fix, the links do not work.
Who can post this fix.
Thank you
lens fix P9 LineAgeOS 14.1 build v1.2.6
The following users say thank you to strjaz for this useful post:
steve98124
steve98124
477
2018/09/20 - 18:20
Thank you
strjaz:
Looks like the Pipo threads here are barely alive.  Glad to see someone is still using their P9.
We have seen no sign of our esteemed developer Oma in quite some time.
I still get a lot of use from my P9  for video with HDMI to my TV.  I get some instability and freeze ups but I think that's due to the cpu struggling under the load.  But mostly it still works pretty well.
Here is a link to the lens fix.
https://www.dropbox.com/s/zu0fp2y3nhqcvxl/Oma_RK32_P9_lens_fix.zip?dl=0
Let me know if this works for you.  Good luck.
vurkan24
478
2019/03/19 - 15:58
dont work download lilnks
Hodgy
Advanced Member
Forum Posts: 154
Thanks Received: 8
479
2019/03/20 - 03:48
Try this.
https://www.dropbox.com/s/70aiz7w4e76k6nk/Oma_RK32_P9_lens_fix.zip?dl=0
Hodgy
Advanced Member
Forum Posts: 154
Thanks Received: 8
480
2019/03/20 - 04:03
... and this if you need the ROM & TWRP
https://www.dropbox.com/sh/jhghf3nr691b5os/AADWgJVd1SVuVBE32s7NEEvra?dl=0
The following users say thank you to Hodgy for this useful post:
postatomic
85 Guest(s)
Devices in use: Desktop (76), Phone (9)
KuPuK
aminpk
GUCHEZ MICHEL
errorsdoc
patricktron
jackmiller5623
