Maestro88 said
also bootloop (
Not really an idea for now. Tomorrow is another day.
2017/05/02
OK,thank you!
Oma, bootlloop problem in "kernel".
I changed "kernel" from build v1.1 in new build v 1.2.1 and no bootloop, but touch screen not work. If used "kernel" from test builds v1.2 and 1.2.1 will be bootloop!
2016/04/14
Maestro88 said
OK,thank you!
same bootloop problem after lower format and run. Cannot actually to hard power-off; had to open up and disconnect battery ribbon. When I reconnect, goes straight back into bootloop. Maybe need to leave it disconnected for longer time. Will wait until tomorrow then try to get into flash mode and start again with updated kernel img ...
2013/04/28
Maestro88 said
OK,thank you!
what about if you flash with a K&M kernel instead?
Pipo P9
2013/04/28
Pls try this one: http://crewrktablets.arctablet.com/?wpfb_dl=3008
Flash kernel and resource.
2013/04/28
So it boots into TWRP? Do you have touch?
2013/04/28
Yes, with CM14 + K&M #85 kernel it boots automatically in recovery and I do hve touch but thats it.
I swaped the USB cable and got the loader mode again and flashed the new version with the respective kernel and resource file.
This new version bootloops also like previous ones and can't even enter in recovery so problem is indeed the kernel
Pipo P9
Ok. Old kernel are useless, the selinux is too old.
Can you pls try these two?
http://crewrktablets.arctablet.com/?wpfb_dl=3009
2017/05/02
Can you pls try these two?http://crewrktablets.arctablet.com/?wpfb_dl=3008
Hello Oma!
Also bootloop (
63 Guest(s)
Devices in use: Desktop (55), Phone (8)
Cellarin
kuzin
Dag58
montolla
portvein
POELE
