[ RK3288 ROM ] Pipo P9 LineAgeOS 14.1 custom root firmware (2017/01/01)
Djuganight
Portugal
Forum Posts: 98
316
2017/06/18 - 23:03
Djuganight said
My Pipo P9 is not charging when its on.
I have to turn it off to charge it....
While the tab is on the 0.5 A is not enough to charge the battery.
I have several fast chargers including Samsungs and none works.
The tablet has been all day turned off and charging and when I connect it just have 12%.....
This doesn't make sense m8 and it would be nice if you could fix it.
Pipo P9
Thanks Received: 1374
317
2017/06/19 - 21:54
I agree this does not make sense. The tab will not go to sleep, while USB is plugged.
Anyway, P9 is A/C charger.
Djuganight
Portugal
Forum Posts: 98
318
2017/06/19 - 21:57
what you mean?
Pipo P9
319
2017/06/19 - 21:59
Finally, here is a P9 fix for battery stats (install via TWRP): http://crewrktablets.arctablet.com/?wpfb_dl=3089
Playing 6 hours 1080p video in mkv format 🙂
v1.2.5_09.pngImage Enlargerv1.2.5_09a.pngImage Enlargerv1.2.5_09b.jpgImage Enlarger
sp_PlupAttachments Attachments
Maestro88, Hodgy
Maestro88
Forum Posts: 79
321
2017/06/20 - 00:23
Amazing! thank you very much Master!
If you compare time with CyanogenMod 13, is it the same time?
raxnaz
Forum Posts: 20
322
2017/06/20 - 17:49
Next P4 kernel:
http://crewrktablets.arctablet.com/?wpfb_dl=3090
http://crewrktablets.arctablet.com/?wpfb_dl=3091
Pls test hal sensor and battery stats.
After applying the patches one by one, I have seen no apparent fix for the magnet sensor:
Applying #6:
- sound / headset detection WORKING
- manual brightness WORKING
- magnet sensor NOT WORKING
- volume rockers WORKING
Applying #7:
I have been playing with the sensors option on CPU X app, and I have seen there is a change on the magnetic fields when I close the lid, so I'd say the magnetic sensor is working.
About the battery stats I don't really know what I should be seeing so, I couldn't say.. :-s
Thanks for all the efforts! 😉
323
2017/06/20 - 18:26
Ok, pls check with this app: https://play.google.com/store/apps/details?id=at.lab.sensorcollection
Use a mobile speaker or similar to find the sensor.
v1.2.5_10.pngImage Enlarger
raxnaz
Forum Posts: 20
324
2017/06/20 - 19:26
I did the check. The sensor is more or less in the middle of the side where the front camera is located. (4 cms centered)
Hope this helps!
raxnaz
Forum Posts: 20
326
2017/06/21 - 19:19
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=3092
Still no luck 🙁
Applying #8:
327
2017/06/24 - 09:39
Thanks for testing! For now no idea. We will however keep this on the to-do list.
raxnaz
328
2017/06/24 - 09:40
Anybody here with a Krüger & Matz tab? Pls check P9 build as-is on 1064 and 1065 hardware revisions.
Maestro88
Forum Posts: 79
329
2017/06/24 - 12:57
The battery works well with this fix.Thanks a lot master Oma!!!
I would like to overclock the GPU to 700mhz,
Oma is it possible on the last kernel (№16)?
Maestro88
Forum Posts: 79
330
2017/06/25 - 13:21
Also noticed the CPU is running at 1.6 GHz (max) with the latest fix.
94 Guest(s)
Devices in use: Desktop (90), Phone (4)
kiler556
andywierz
Yosijodo
moncef
YuT666
andreiolv
Topics: 6028
Members: 261259
