2013/04/28
2017/05/02
Djuganight said
Flash v1.1 and I can go into TWRP but the touchscreen doesn't work.I noticed that TWRP and paramenter files are different in V1.1 and V1.2
The parameter in v1.1 is a txt. file and in v1.2 its not Â
me too ) on test build v1.1 and 1.0
Need wait fix for buiild v1.2 from Master Oma!Â
parameter_cm14.1 Â file extension "1"
Fine. 3G tab or Wifi only tab or any clone of P9?
It is mandatory to do a clean install, incl. Lower Format.
Maybe a wiping issue. Pls reboot into recovery and format data again.
On the fresh build pls do dmesg and logcat logs. Here is a tool: https://forum.xda-developers.com/showthread.php?t=1944776
Djuganight said
Just installed but its endless bootloop in Rockchip Kernel logoMaestro88 said
Logo Kernel and reboot, logo,reboot again again
Both wifi only P9, right? Pls also check the wiping process.
If it still loops at kernel logo pls go back to recent firmware and provide logcat and dmesg log from a fresh boot. Pls also plug in/out a device on the usb-otg a few times before doing the logs.
2013/02/28
Hi again
Still have this wifi problem, tablets says it is not connected to internet but refresh wifi I can DL some apps from Play store but in the end of the process it comes up with error like 400-900-460 I seen so far.
I tried both version 1.1 and 1.2 really like this its like my old trustu P9 is like new again, eept for this wifi problem.
Best regards
Jens
Works flawlessly here on my hardware. Pls let me have the logs from this situation.
2017/05/02
Can you make logs? (dmesg log via AIOlog)
I can not do it, it does not work.Never did )
AIOlog Writes: Device ID , where to get this ID?Â
My tablet PIPO P9 WI-FI old revision, CM13 working perfect!Â
2013/04/28
Logo Kernel and reboot, logo,reboot again againBoth wifi only P9, right? Pls also check the wiping process.
- Oma -Â Â
Yes mine is wi-fi but how can I check the wiping process if it won't enter in recovery?
In V1.1 i can enter in recovery but no touch so I can't do anything
Pipo P9
2016/02/04
Hi !! Oma thank  you for lineage for pipo p9!!!
I have installed linage version 1.2 and tested it a bit and found such problems:
- Flashlight don't work
- Â 3g data don't work. Tablet cannot register into the lifecell's cellular network.
- There is no adaptive brightness into the display settings.
- What is about hdmi, is it working?Â
I have made some logs with syslog. Maybe they will be useful
Thank you for feedback!
This is still a testbuild, but the Android is already pretty good. Kernel is still under heavy construction. All 4 issues reported are driven by this. So, any log will help.
Maestro88, Djuganight:
Pls test this kernel with v1.2 build: http://crewrktablets.arctablet.com/?wpfb_dl=3007
Just replace both files in folder rockdev/Images and do a clean install, incl Lower Format.
2017/05/02
Pls test this kernel with v1.2 build: http://crewrktablets.arctablet.com/?wpfb_dl=3007Just replace both files in folder rockdev/Images and do a clean install, incl Lower Format.
- Oma -Â Â
also bootloop (Â
69 Guest(s)
Devices in use: Desktop (62), Phone (7)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
