Gents,
LineAgeOS 14.1 has landed on Pipo P9 😉
CrewRKTablets RK32 P9 LineAgeOS 14.1 build v1.2.6 - 12.08.2017 (Google August security patches)
- 3G off for wifi only tabs (install via TWRP)
For Pipo P4 change kernel/resource in folder rockdev/Image before flash.
CrewRKTablets RK32 P9 LineAgeOS 14.1 final build v1.2.5 - 10.06.2017
- lens fix - if build stops in bootanimation
- improve battery stats - for P9 and clones only !
Will work on all hardware revisions, incl. Krüger&Matz clones.
For the new 4G revision - 4G fix (not tested yet)
CrewRKTablets RK32 P9 LineAgeOS 14.1 build v1.2.4 - 23.05.2017 (with common kernel 3G, wifi, VTL, Goodix)
- mandatory: change kernel/resource in folder rockdev/Image first
CrewRKTablets RK32 P9 LineAgeOS 14.1 build v1.2.3 - 21.05.2017 (with common kernel 3G, wifi, VTL, Goodix)
- framebuffer fix - if there are scrolling issues
CrewRKTablets RK32 P9 LineAgeOS 14.1 build v1.2.2 - 15.05.2017 (with common kernel 3G, wifi, VTL, Goodix)
- some fixes (replace files in folder rockdev/Image before flash)
CrewRKTablets RK32 P9 LineAgeOS 14.1 build v1.2.1 - 09.05.2017 & kernel opt battery stats (change in folder rockdev/Image)
CrewRKTablets RK32 P9 LineAgeOS 14.1 testbuild v1.2 - 04.05.2017
CrewRKTablets RK32 P9 LineAgeOS 14.1 testbuild v1.1 - 17.04.2017
CrewRKTablets RK32 P9 LineAgeOS 14.1 testbuild v1.0 - 01.01.2017
– recovery TWRP 3.0.0.0
– homebrew sekernel @ 1.6 GHz
– unified storage
– LineAgeOS su, su-binary
– pico gapps
not working:
- tested on P9 3G tab with VTL touch, pls report issues on other hardware revisions (with full logs)
hints:
– developer options: enable by tapping 5 times onto build number (settings/about the tab)
– screenshots: enable in settings/buttons/power menue
– advanced reboot: enable in settings/developer options
– root access: enable in settings/developer options (apps and adb)
– local terminal: enable in settings/developer options
– better UI performance: set all animation scales to 0 in settings/developer options
– use Airplan mode to switch modem off completly (wifi could still be enabled)
– use Volume Booster Goodev (see Playstore) to increase audio volume
– use BatterySpy (see Playstore) to report battery stats
– use Substratum (see Playstore) to theme the build
– use Xposed to pimp the build in any other way
Special thanks to netlars & mussonero
– Oma -
Maestro88, Hodgy, Hodgy, weereew, 4thjak, omar11Per aspera ad astra, we rock the Tablets !
2017/05/02
Oma, Guru, Thank you for firmwares! You Best, Master!
Cyanogen 13 working perfect for my tablet!
But on LineAge OS 14.1 don't working touchscreen! Touchscreen Goodix.... Tablet Wifi version, no 3G
If you can create fix for "goodix touchscreen, I will be Happy.
Thanks a lot, for you work CrewRKTablet Team with Master Oma!
P.S Sorry for my bad English...
Please test: http://crewrktablets.arctablet.com/?wpfb_dl=3002
If no touch please provide a dmesg log. Do it via PC (adb is on per default): https://forum.xda-developers.com/showthread.php?t=1944776
2017/05/02
Please test: http://crewrktablets.arctablet.com/?wpfb_dl=3002If no touch please provide a dmesg log. Do it via PC (adb is on per default): https://forum.xda-developers.com/showthread.php?t=1944776
No, don't working (
dmesg I can't do! I will be wait stable version LineAge OS on PIPO P9. First build CM13 alsо not working touchscreen on my device, but after became Good working! Big Thanks master Oma for you help and work!
2013/04/28
First I would like to thank you a million for your continuous effort OMA. Gladly we have people like you otherwise if we would have to rely on the manufacturers it would be a very grey world.
Downloading ATM for testing.
I am back to 5.1.1 since CM13 never worked well on my tablet, always extremely buggy and laggy at the point to be painfull lol.
Will we need lens fix?
Pipo P9
There are a lot of hardware revisions in the field, but yours was still a bad boy 😉
I will upload the last testbuild in a few minutes. If it loops try the lens fix. Also dmesg and logcat logs would be useful.
2013/04/28
2013/04/28
Ok, link now working. Doesn't matter if you have wifi only tab.
2013/04/28
2013/04/28
65 Guest(s)
Devices in use: Desktop (55), Phone (10)
