[ RK3288 ROM ] Pipo P9 CM13 6.0.1 custom root firmware (2016/01/30)
Hodgy
Advanced Member
Forum Posts: 152
Thanks Received: 7
796
2017/05/10 - 05:06
4thjak said
and the new rom is out... Lineage OS.
New ROM out? Is that in the 'unofficial builds' list on lineage website?
weereew
Forum Posts: 13
797
2017/05/11 - 05:39
how about the brand new rom, less bug?
Hodgy
Advanced Member
Forum Posts: 152
Thanks Received: 7
798
2017/05/11 - 15:30
Found it. Will test when I get some time.
H*2
799
2017/09/15 - 03:56
So I have RK32 P9 CM13 6.0.1 final build v1.5.3 loaded on my Pipo. Everthing was working great up until about three weeks ago.... My tablet sporadically reboots? Has anybody else had this problem and what can be done about it?
Hodgy
Advanced Member
Forum Posts: 152
Thanks Received: 7
800
2017/09/15 - 04:17
If it were me I'd do a clean install including lower format and erasing the partitions as per Oma's instructions. Is there any reason you're not on Lineage 14.1, final build 1.2.6? It'sworking great on P9, seems better than Lineage CM13 ever did for me.
Ian
Edit: Don't forget to do a data backup first. Maybe you shouldn't back up system and boot because the issue you're having could be in there somewhere. And anyway, if you do a clean install those partitions are all included anyway.
hawkdown77
801
2017/09/15 - 17:26
Hi. whats the best way to do a Nandroid Backup.... cause i want install more new version and if this go wrong i can recover to last rom working with my apps..... im using PIPO P4 1.3.0
Thank you.
Hodgy
Advanced Member
Forum Posts: 152
Thanks Received: 7
802
2017/09/16 - 02:22
Thank you.
Do it through TWRP recovery then move the backup to SD card or PC - quite a large file. Have a look at a couple of videos on YouTube before you you do it - it's very simple. Takes 5-10 minutes because it's a big file.
Ian
H*2
803
2017/09/19 - 05:18
I am attempting to load RK3288: Pipo P9 LineAgeOS 14.1 Edition.
Help....I am still new to most of this. How do I load new firmware with a .7z file name. I also want to load a new kernel which is also a .7z file. I have tried TWRP Recovery put it does not recognize .7z files. What am I missing?
Please provide step by step instructions...I am not finding instructions in the packages.
Thanks,
Harry
Hodgy
Advanced Member
Forum Posts: 152
Thanks Received: 7
804
2017/09/21 - 15:24
http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-pipo-p9-lineageos-14-1-custom-root-firmware-20170101/
Thanks,
Harry
If you 1st extract the 7z file to your C drive, you'll see the android tool, wich you use to flash the ROM (not TWRP). I do it in Windows 7 compatibility mode, via USB 2.0. Just follow all the instructions in the text file in the download pack. First you have to install the drivers: there's an easy little tool for that too in the folder. And if you have a different kernel you want to flash, just replace the kernel.img file in the rockdev folder. Also, make sure USB plugged in before booting to flash mode. If something goes wrong and you get a boot loop you can always get back into flash mode this way. If you do get a boot loop after following the instructions, then before you try starting again, unplug the USB, boot into TWRP and flash the P9 lens fix (should be on post #1 of this thread).
Hope you manage it. I'm no techy but can manage the process fine, so you should be absolutely fine.
Ian
PS: there is an android 7 ROM on this forum which works well (I tried to paste it here but it keeps going to the top of the post)
H*2
805
2017/10/09 - 22:38
 I am still having problems with releases CM13 and CM14 on my P9. The issue surfaced when I downloaded the NPR app…the Nova launcher would shut down and the system would reboot constantly. I have wiped, Cleared, Reset and flashed the roms multiple times with 13M but Nova will not work without rebooting the system; release 14M is a tad worse. Yet I was able to install the Apex Launcher successfully. Nevertheless, I am still having issues downloading apps, such as CBS, Pluto TV and most video type apps, the system shuts down the Apex launcher and reboots. At this time I am using 13M.
Any feedback would be helpful.
Harry
Hodgy
Advanced Member
Forum Posts: 152
Thanks Received: 7
806
2017/10/10 - 01:42
H*2 said
 I am still having problems with releases CM13 and CM14 on my ... I have wiped, Cleared, Reset and flashed the roms multiple times with
When you installed did you hit 'lower format' before 'run'? Then when the tab boots into TWRP did you do both 'format dated and then after that, 'factory resetc also?
Ian
H*2
807
2017/10/10 - 02:17
Ian
Yes, I followed the instructions each time.
1.Lower Format, 2.Run, 3.Wipe, 4.Format Data, 5.Factory Reset
Dave5322
808
2017/11/29 - 12:39
Just wanted to tell anyone using this firmware not to update the "Volume Booster GOODEV" app, as my tablet was crashing after I updated it.
AndreasKal
809
2017/11/30 - 07:28
This happened to me as well a month ago. I should have reported it here, to save you from the problem. Sorry.
Dr_IT
810
2018/01/12 - 17:15
I installed this rom 2 months ago on my Pipo P9 (as v14 did have problem of reverse touch screen).
But now i found out bluetooth is not working. When wanting to tun it on in settings by setting the slider to on, it stays greyed out (instead of turning green) and after refresh it has reverted back to off.
Did a quick check with syslog and see that bluetooth process is set to on every 10 seconds and then dying, etc.
Also tried some bluetooth apps which set it to on, but some of those let play services, trebuchet, etc crashing and as such rebooting the device.
Does anyone have ancountered this before and/or knows a solution?
83 Guest(s)
Devices in use: Desktop (77), Phone (6)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
