[ RK3288 ROM ] Pipo P9 CM13 6.0.1 custom root firmware (2016/01/30)
Thanks Received: 1383
61
2016/02/05 - 05:55
jastaz23 said
Btw hdmi works with this rom (1.1) no manual scaling/resolution and zoom since it doesn't have a control panel for hdmi in the settings you wont see the notif panels...
Thank you for feedback! HDMI settings is on the to-do list.
4thjak
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
62
2016/02/05 - 06:16
Can't find Trebuchet settings... please help.
HAHA Found it! I should be in the launcher itself to find the illusive settings.
Thanks again kind sir, looks like my dream is here to stay.
Pipo M8pro
Pipo M9pro
Pipo P4
Paralel
63
2016/02/05 - 06:29
I can use this on the P7, if I use the P7 kernel linked in the first post?
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
64
2016/02/05 - 06:56
sorry, but the problem is still there. It's no longer stuck in portrait, autorotate is not functioning porperly anymore. Screen won't rotate unless forced by an app then returns to landscape view. After that, rotating the tab the screen does not follow.
I really wish I did bought the P9 or the P1...
Pipo M8pro
Pipo M9pro
Pipo P4
DimaBr
Forum Posts: 52
65
2016/02/05 - 07:02
Hi!!!
What is about 3G and gps? Are they working in the last build?
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
66
2016/02/05 - 12:18
Funny how my problems about the rotation and being stuck in portrait mode seem to have flown away. My unit is back to normal, no more stuck in portrait mode... then I realized I have removed the sd card.
I think the SD card is the culprit, but can't live without it.
Pipo M8pro
Pipo M9pro
Pipo P4
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
67
2016/02/05 - 15:37
Everything is ok now since the removal of my sd, inserted my sd card and it has no notif when inserted but detected in settings/storage, and in file explorer.
Only bad thing now is the rotation, a bit slow and laggy. I'll be staying with this for a while.
Pipo M8pro
Pipo M9pro
Pipo P4
68
2016/02/05 - 15:41
Pls do a clean install (with LowerFormat) of build v1.2.
4thjak
jastaz23
Forum Posts: 28
69
2016/02/05 - 17:17
One major issie for my tab (P4) is that it won't recognize and earphone/headset , no notif icon and sounds are still coming out of the speaker...
70
2016/02/05 - 17:19
I guess this is the same in LP build?
jastaz23
Forum Posts: 28
71
2016/02/05 - 18:43
Nope in LP earphones works perfectly
I've reverted back the tab to LP now...
paronen
72
2016/02/06 - 19:43
Sir Oma,
I seem to be a perpetual noob - or maybe I don't try to mod my P9 (WiFi only) often enough.
Anyway, I believe I've followed the instructions in #1 to the letter.  I end up in a "Android is starting...Starting apps." bootloop.
Two questions:
1) Does the CM13 6.0.1 v1.2 Mod work on WiFi only tabs?
2) What exactly is the procedure for applying the "Oma_RK32_P9_lens_fix.zip"? Where exactly do I place the files when I unzip the ZIP file, and how do I then apply so that I avoid the bootloop? Is this information in an FAQ file you can point me to?
Your work here is phenomenal.  I appreciate any advice from you -
Regards,
paronen
paronen
73
2016/02/06 - 19:55
LowerFormat.jpgImage EnlargerRun.jpgImage EnlargerOptimizing.jpgImage EnlargerStarting-apps-bootloop.jpgImage EnlargerOma7144 said
Gents,
Marshmallow has landed on Pipo P9   ;-)
CrewRKTablets RK32 P9 CM13 6.0.1 build v1.2
- P9 lens fix
- P4 kernel #70 (change files in folder rockdev/Image) before flash
- P7 kernel #65    ''
- P1 kernel #71    ''
outdated:
CrewRKTablets RK32 P9 CM13 6.0.1 test-build v1.1 (only for tabs with VTL touch controller)
CrewRKTablets RK32 P9 CM13 6.0.1 test-build v1.0 (only for tabs with VTL touch controller)
For other hardware revisions one may use the stock kernel (change kernel and resource in folder rockdev image before flash): http://crewrktablets.arctablet.com/?wpfb_dl=2687 (unplug sdcard, otherwise you will get a bootloop)
– recovery TWRP 2.8.7.0
– sekernel #69
– unified storage
– Multi-Windows
hints:
– enable UI rotation in Trebuchet settings
– Oma's favourite apps for MM
– Xposed Framework starter pack
– Oma -
crew-1.pngImage Enlargercm13_01.pngImage Enlargercm13_03.jpgImage Enlargercm13_04.jpgImage Enlargercm13_05.pngImage Enlargercm13_06.jpgImage Enlargercm13_07.pngImage Enlargercm13_08.pngImage Enlargercm13_10.jpgImage Enlargercm13_011.pngImage Enlargercm13_012.jpgImage Enlargercm13_015.jpgImage Enlargercm13_014.pngImage Enlargercm13_017.jpgImage Enlargercm13_018.pngImage Enlargercm13_020.pngImage Enlargercm13_019-1.jpgImage Enlarger
Sir Oma,
Two questions:
Regards,
paronen
Bergyver
Forum Posts: 18
74
2016/02/06 - 21:33
I have been using version 1.2, from time to time a little lag, nothing a reboot won't solve. Battery stats same story not accurate. 3.5mm Jack for phones not working. This are the main issues I found so far.
In the big picture It's the excelent work that rules.
Best regards.
kallesone
Forum Posts: 46
Thanks Received: 7
75
2016/02/06 - 22:54
paronen said
Sir Oma,
Two questions:
Regards,
paronen
Hi paronen.
Well,after install the rom wait for stock recovery and then,when stuck on starting apps screen,put the tablet on loader mode and instal twrp recovery.And in twrp recovery install lens fix putting the archive on a sd card.
This may work,enjoy and regards.
The following users say thank you to kallesone for this useful post:
paronen, Oma7144
67 Guest(s)
2 Guest(s)
Devices in use: Desktop (58), Phone (9)
Cellarin
kuzin
Dag58
montolla
portvein
POELE
