[ RK3288 ROM ] Pipo P9 CM13 6.0.1 custom root firmware (2016/01/30)
kallesone
Forum Posts: 46
Thanks Received: 7
46
2016/02/04 - 11:06
I don´t know what i´m doing wrong.
Install 1.1 version changing the kernel/resource from #69 version.
Stock recovey makes the factory reset and system boots.
Optimizing apps 87/87 OK.
And them...,stucks on android is starting...starting apps screen.
DimaBr
Forum Posts: 52
47
2016/02/04 - 11:24
Hi !!
I have install test-build v1.1 on my 3g pipo p9 and have unworking gsm module (no sim card), gps and cannot find autobrightness.
The following users say thank you to DimaBr for this useful post:
kallesone
paparazzo_1
Forum Posts: 55
Thanks Received: 4
48
2016/02/04 - 11:30
Do you tried 1.0 version? I use 1.0 now.
The following users say thank you to paparazzo_1 for this useful post:
kallesone
kallesone
Forum Posts: 46
Thanks Received: 7
49
2016/02/04 - 13:07
Thx for your help.
At least is working...and it was my fault.
Installing 1.1 version,wait for stock recovery,then install twrp and install lens fix...and voila!!!.
Sorry for the inconvenients.
Regards.
P.D.:All working fine,thx Oma.
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
50
2016/02/04 - 16:01
I really would love to stay at this rom... but I'll just have to dream of MM on my tab some more, and wait for another magic from sir Oma.
Pipo M8pro
Pipo M9pro
Pipo P4
51
2016/02/04 - 23:17
Update post #1 with build v1.2.
Build will boot on any LP stock kernel and the sdcard is not longer an issue 😉
cm13_v1.2_02.pngImage Enlarger
jastaz23, raptyk
jastaz23
Forum Posts: 28
52
2016/02/04 - 23:47
I was about to write my feedback today, regarding the sdcard and usb otg not being rexognize by the rom, will try this one first. Thanks!
Btw hdmi works with this rom (1.1) no manual scaling/resolution and zoom since it doesn't have a control panel for hdmi in the settings you wont see the notif panels...
raptyk
Forum Posts: 20
53
2016/02/05 - 00:01
Guys... Is there any workaround/fix/3rd party app for inacurate battery stats? It is horrible to don't know real batt level. See attachement :/Screenshot_2016-02-04-23-57-30-1.pngImage Enlarger
Bergyver
Forum Posts: 18
54
2016/02/05 - 00:22
Amazing is just the word I find to describe this work, after a very long and hard day of work my feedback it's that it's flawless,no brakes, no lag, no rebooting, no nothing. The only thing was really the battery I had to go 3 times to the wall charger, and as you know it takes quite a time to charge and I was not used to it.
So the question is should I stay at this version 1.1, or move to the next one 1.2?
Thank's in advance.
Best regards.
Bergyver
Forum Posts: 18
55
2016/02/05 - 00:39
how did you get the volume buttons and the screenshot too?
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
56
2016/02/05 - 02:00
WOW! I haven't restored, and my unit is ready to be filled up again... but then again I dreamt of Mallows... now lets taste that dream come true. Thanks for your love sir Oma...
Pipo M8pro
Pipo M9pro
Pipo P4
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
57
2016/02/05 - 05:01
This rom is great, but again the rotation being stuck in portrait mode hinders me to stay on this rom. When an app forces the view into portrait, it stays there.
The solution is to turn off the autorotate in Display and Lighting. But then again, portrait mode is needed in reading PDF and blogs. Or You can lock the tab, rotate the tab physically in all sides, and hope that unlocks portrait mode, it sometimes works.
Wow, almost had this CM13 MM 6.01 V1.2. Tonight, I'll be going back to my peaceful life in sir Oma's LP v1.0 rom. Thanks kind sir Oma!
Pipo M8pro
Pipo M9pro
Pipo P4
58
2016/02/05 - 05:34
hints:
– enable UI rotation in Trebuchet settings
Enabling the UI rotation in Trebuchet settings will do the trick.
allow-rotation-in-Trebuchet-settings.pngImage Enlarger
59
2016/02/05 - 05:40
Bergyver said
The shown picture is not from the CM13 build.
However, soft volume keys are standard in build v1.2. For screenshots one can enable it in Settings/Power Menue.
Screenshot-via-Power-Menue.pngImage EnlargerScreenshot_20160205-054327.jpgImage Enlarger
60
2016/02/05 - 05:53
This is the Krüger & Matz tab running a LP build, right?
As I can boot the K&M kernel on my P9 you should try the P9 kernel #69. It is not perfect in terms of battery stats, but shows not such a misbehaviour.
51 Guest(s)
Devices in use: Desktop (45), Phone (6)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
