[ RK3288 ROM ] Pipo P9 CM13 6.0.1 custom root firmware (2016/01/30)
2016/01/31 - 20:25
Gents,
Marshmallow has landed on Pipo P9   ;-)
CrewRKTablets RK32 P9 CM13 6.0.1 final build v1.5.3 - CM August sources and security patches
- v1.5.3 3G off (if you have a wifi only tab, install via TWRP)
- v1.5.3 fix audio in arcade games
- add Gello browser (in v1.5.3 already included)
- add HexoLibre - CM dark theme
CrewRKTablets RK32 P9 CM13 6.0.1 final build v1.5.2
- incl. kernel #102 @ 60Hz, high brightness, perfect battery stats
- v1.5.2 fix sensor & audio (mandatory, install via TWRP)
- v1.5.2 3G off (if you have a wifi only tab, install via TWRP)
- if the tab stops with starting apps/bootloop you have a different hardware revision,
  pls install the P9 lens fix via TWRP
- v1.5.2 add HW+ support in MXPlayer (do only install if really needed)
- model fix for P9 clones and P4, P1, P7 see below
v1.5.2_19a-1.jpgImage Enlarger
CrewRKTablets RK32 P9 CM13 6.0.1 build v1.5 - CM July sources and security patches
- v1.5 3G off (if you have a wifi only tab, install via TWRP)
v1.5_05.pngImage Enlarger
CrewRKTablets RK32 P9 CM13 6.0.1 build v1.4.1 (bugfixes and sekernel #102)
- v1.4.1 fix interference GPS/BT
CrewRKTablets RK32 P9 CM13 6.0.1 build v1.4 - CM June sources and security patches
add-on's, if needed (install via TWRP)
- sekernel #102 for perfect battery stats
- v1.4 3G off (if you have a wifi only tab) / - v1.4 3G on
- v1.4 fix USB-stick mounting via settings
- v1.4 fix GPS support (only for P9, does contain resource.img, do NOT use on other tabs!)
- v1.4 fix hotspot support
- v1.4 add widevine engine
- if the tab stops with starting apps/bootloop you have a different hardware revision;
pls start flashmodus by holding Power & Esc, flash the TWRP and install the P9 lens fix
v1.4_23-1.pngImage Enlarger
CrewRKTablets RK32 P9 CM13 6.0.1 build v1.3 - CM March sources and security patches
- v1.3 fix for audio settings, touch volume, auto brightness
- v1.3 improve UI performance
- v1.3 fix audio in phone calls
sekernel #16 for better battery stats (change in folder rockdev/Image before flash)
CrewRKTablets RK32 P9 CM13 6.0.1 final build v1.2.4b
CrewRKTablets RK32 P9 CM13 6.0.1 build v1.2.3
CrewRKTablets RK32 P9 CM13 6.0.1 build v1.2.1
For other Pipo tabs change kernel/resource in folder rockdev/Image before flash
and install the fixes via TWRP. DPI can be changed in settings/display&lights:
- P4 sekernel #70 , no model fix necessary
- P7 sekernel #65 , model fix, v1.5.2 model fix
- P1 sekernel #24 , cam fix , 320 DPI - use CPU Awake (see PlayStore) when kernel #24 shows deep sleep issues
- KM1065G sekernel #85 , sekernel #183  , no model fix necessary
- KM1064.2 sekernel 184 screen 1920x1200, wifi
- KM1064.1G sekernel #55 screen 1280x800, 3G
- KM1064.1 sekernel #56 screen 1280x800, wifi
– recovery TWRP 2.8.7.0
– recovery TWRP 3.0.0.0 [v1.2.3]
– sekernel #69
– sekernel #16 [v1.3, v1.4]
– sekernel #102 [v1.4.1, v1.5]
– sekernel #102 @60Hz [v1.5.2]
– unified storage
– Charger Mode [v1.2.3]
– Multi-Windows
– Stagefright patch
– CM superuser
– 3G support [v1.2.3]
– GPS support [v1.2.3]
– HDMI support [v1.2.4]
– Ethernet support
– exFat support
– wifi display support [v1.5.2]
– significant modtion support [v1.5.2]
– Viper4AndroidFX compatible
– Xposed Framework compatible
– Netflix compatible
– Kodi 16.0 / 16.1 compatible
– Emulator compatible
hints:
- instructions are included in the download pack
- rotation of the UI: enable Allow Rotation in trebuchet settings
- screenshots: enable in settings/power menue
- developer options: enable by tapping 5 times onto build number (settings/about the tab)
- advanced reboot: enable in settings/developer options
- root access: enable in settings/developer options (apps and adb)
- local terminal: enable in settings/developer options
- multi-window mode: enable in settings/developer options
- better UI performance: set all animation scales to 0 in settings/developer options
- mass_storage mode is gone in Android 6.0 > use MTP
- battery stats: let the battery run empty at least one times and load it fully (MM needs
to learn the stats)
– Oma's favourite apps for MM
– Xposed Framework starter pack
>>> to go back to KK pls stay with the included loader or use the stock v2.19 loader
– Oma -
crew-1.pngImage Enlargercm13_01.pngImage Enlargercm13_03.jpgImage Enlargercm13_04.jpgImage Enlargercm13_05.pngImage Enlarger
v1.2.3_07-1.jpgImage Enlargerv1.2.3_02-1.pngImage Enlargerv1.2.3_19-1.jpgImage Enlargerv1.2.3_022-1024x640.pngImage Enlargercm13_06.jpgImage Enlargercm13_07.pngImage Enlargercm13_08.pngImage Enlargercm13_10.jpgImage Enlargercm13_011.pngImage Enlargercm13_012.jpgImage Enlargercm13_015.jpgImage Enlargercm13_014.pngImage Enlargercm13_017.jpgImage Enlargercm13_018.pngImage Enlargercm13_020.pngImage Enlarger
v1.2.4_27-1.pngImage EnlargerLP_kernel_missmatch_voltage_battery_stats-1.pngImage Enlargerv1.2.4_26-1.pngImage Enlargercm13_019-1.jpgImage Enlarger
TWRP.jpgImage EnlargerTWRP_001-1.jpgImage Enlarger
admin, Bergyver, 4thjak, paronen, tarjan, haytham_subzero, H*2, Dave5322, omar11
raptyk
Forum Posts: 20
2016/01/31 - 22:27
OMG, wow - 100% working ? (cam, flash, 3g, sd, root, battery stats)
PS. I've stock ROM from my manufacture (Kruger&Matz1065 with 3G - P9 clone) - should I also upload loader? It is unchecked by default...
Image Enlarger
kallesone
Forum Posts: 46
Thanks Received: 7
2016/01/31 - 23:39
Thx a lot Oma.Will try and tell you.
Regards.
kallesone
Forum Posts: 46
Thanks Received: 7
2016/02/01 - 12:03
I need help!!!.I tried to install this rom,but in twrp first screen the tablet don´t works.Like the touchscreen don´t work.
And now i can´t install other rom because the recovery don´t recognizes the internall storage and i can´t make a factory reset.
Please help!!!.
raptyk
Forum Posts: 20
2016/02/01 - 12:40
1. Maybe you could try upload another TWRP using instruction in this post -> http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-twrpcwm-flash-tool-custom-root-firmware-20150117/ ?
2. Did u try to use usb mouse/keyboard to click buttons in TWRP ?
What does it mean "recovery don´t recognizes the internall storage" ?
Did u checked "Loader" (first line - see screenshot in post #2) ?
kallesone
Forum Posts: 46
Thanks Received: 7
2016/02/01 - 12:47
Thx.Of course ,i´ve try another twrp version on cm13,but i have the same problem.
Then,i try to install cm12.1 and on twrp i can´t make a factory reset,cause it says can´t mount storage.
raptyk
Forum Posts: 20
2016/02/01 - 12:58
In the first post Oma7144 said:
"– unified storage"... maybe this is a hint to solve your problem? If I understood correctly "unified storage" means that there is no additional partitions. Maybe inserting sd card will help to do factory reset (twrp will recognize sd as ext storage and mount it?) ?
(for me partitions are very tricky... i hard bricked my P9 some months ago when I was trying to change their sizes)
kallesone
Forum Posts: 46
Thanks Received: 7
2016/02/01 - 13:02
Thx,i Will try.
paparazzo_1
Forum Posts: 55
Thanks Received: 4
2016/02/01 - 13:06
TWRP touchscreen DO NOT work.
I have same issue as kallesone.
Any solution?
raptyk
Forum Posts: 20
2016/02/01 - 13:17
So... we're calling @Oma7144 for help and fixes.
kallesone
Forum Posts: 46
Thanks Received: 7
2016/02/01 - 13:24
I can use cm13 twrp version after install cm12.1 1.1,and this version can make a factory reset,but stuck on bootlooping.
paparazzo_1
Forum Posts: 55
Thanks Received: 4
2016/02/01 - 13:36
Okay,I did factory reset with external OTG mouse with TWRP.
But also have an bootloop. Seems I need camerafix. Because CM12.1 have same issues in my tablet
The following users say thank you to paparazzo_1 for this useful post:
raptyk
kallesone
Forum Posts: 46
Thanks Received: 7
2016/02/01 - 15:12
Impossible,i can´t install other rom,allways saying "cannot mount internal storage" on recovery and stucks on bootlogo.
kallesone
Forum Posts: 46
Thanks Received: 7
2016/02/01 - 15:45
At least i can install a rom,the only one who let me was the last pipo.cn beta from 30/12/2015.UFFFF!!!
raptyk
Forum Posts: 20
2016/02/01 - 15:54
good news 🙂 ...but we've still wait for some info from Oma7144
75 Guest(s)
Devices in use: Desktop (69), Phone (6)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
