Gents,
This is a LP build for Pipo P9
– stock recovery 5.0.0
– kernel #30 preempt 17 Jul 2015
– Reboot Menue
not working:
- GPS
- Cam LED
hints:
- Oma's favourite apps for LP (install via apk installer)
– Oma -
kallesonePer aspera ad astra, we rock the Tablets !
Works pretty good. For the moment no GPS.
Negative. One need a specific kernel for another tab.
Can somebody pls test our CM12.1 build on Pipo P9?
Build v1.2.1: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/cm12-1-has-landed-on-rk3288/
Use Kernel #30 and change kernel and resource in folder rockdev/Image before flash: http://crewrktablets.arctablet.com/?wpfb_dl=2606
Edit: choose TWRP 1920 x 1200
First boot is in TWRP: do a factory reset and install this P9 model fix (updated): http://crewrktablets.arctablet.com/?wpfb_dl=2632
Reboot system and wait 3 minutes.
2015/07/01
WOW,
CM12.1 is great, thanks for the build.
While installing I had to use TWRP_1920x1200_CrewRKTablets_v3.0.img from the AOSP P9 package. The resolution was too big to fit the screen.
Now testing the performance, it's very smooth (subtitles "lag" on Kodi player is gone). Got 35652 from Antutu benchmark.
Some notes so far:>
- No camera, front or back
- No GPS
- Bluetooth speaker doesn't work (weird noises, or no sound). Internal speaker seems to work ok
- Backlight adjustment doesn't work
- DPI setting too high, maybe 240 ok
Thank you for testing! Can I have a screenshot of settings/about the tab?
Sorry, I haven't thought about TWRP. However, you have found a good one.
Here is a brunch of TWRP's: http://crewrktablets.arctablet.com/?p=5336
Camera I am not sure at the moment.
GPS is a missing driver in the kernel #30.
As for bluetooth speaker and backlight adjustment: is this working in ASOP with kernel #30?
The dpi could be adjusted in settings/display. P9 has 240 dpi.
2015/07/01
The following users say thank you to calestrom for this useful post:
Thanks!
Ok, first try to correct dpi=240, screen brightness settings and cam: http://crewrktablets.arctablet.com/?wpfb_dl=2632
Hm, just guessing: - not working -. Pls test also BT audio.
Ok, that crashed the cam. Thanks for the moment. Need to dig deeper.
55 Guest(s)
Devices in use: Desktop (48), Phone (7)
