[ RK3288 ROM ] Pipo P9 AOSP 5.1.1 custom root firmware (2015/06/03)
olkogolic
46
2015/07/13 - 18:53
audio no fix full ((
gra3l
47
2015/07/15 - 11:02
Hi Oma, I am new here. Just flashed my Pipo P9 with your Lollipop test build 1.1. I got these issues:
1.) same crappy/noisy audio as KenMic35 wrote about
2.) no 3G (only message "insert SIM Card")
3.) no GPS
4.) no front cam
5.) no lcd auto-brightness
6.) rear cam works including flash, but unable to use Lollipop feature "FlashLight" (minor issue)
Thank you very much for your work.
I can provide any log you want, if I know how to get it.
48
2015/07/26 - 19:32
Thank you guys for feedback!
Could somebody pls test kernel #30? Just change kernel and resouce in folder rockdev/Image before flash.
Should solve the main issues battery, audio and touch.
calestrom
Forum Posts: 30
49
2015/07/26 - 21:32
Thanks a million Oma,
Touch works. Audio OK! Performance is great (37000 antutu)! It's a new life for my P9.
Didn't get GPS fix. Is it not working?
The donate button is getting a click for sure 🙂
KenMic35
Forum Posts: 54
50
2015/07/26 - 21:56
WOW !!!
Audio works great!!!
Thank you OMA!!! I am now officially a Lollipop user....bye bye KitKat
Rear Cam flash works fine too using build 1.1 (no need to flash the fix via TWRP)
GPS still not working but i don`t care i have audio now! :))))
My P9 looks more powerful LP brought a new life to this great tablet!!!
Just a quick note...
I just noticed that when i hold the Power button for a few seconds (forced shutdown) the tablet does not power off it just reboots.
Also the flashlight icon on the pulldown notification menu does not work.
KenMic35
Forum Posts: 54
51
2015/07/27 - 10:03
dear oma,
I am confused by which LP rom is the latest.
On http://crewrktablets.arctablet.com/ there are....
P9 by Oma LP 5.1.1 build v1.0 (26. Juli 2015)
Oma_RK32_P9_LP_5.1.1_v1.0a.7z
P9 by CrewRKTablets AOSP 5.1.1 build v1.0 (11. Juni 2015)
CrewRKTablets_RK32_P9_LP_5.1.1_v1.1.7z
Should i use/flash the rom in this thread in post #1???
52
2015/07/27 - 15:43
KenMic35 said
P9 by CrewRKTablets AOSP 5.1.1 test build v1.0 (11. Juni 2015)
If the AOSP test build is good for you stay with it. I hope I will get sufficient feedback for the Lollipop Edition. Cross references will help in the trial and error process. This here is still time consuming reverse engineering.
KenMic35
Forum Posts: 54
53
2015/07/27 - 16:15
with the new kernel #30 the cpu is capped @ 1.6ghz instead of 1.8ghz
I just had the first random reboot with this rom 🙁
Also can you make the lower navigation bar buttons in this order pls?
v1.0_03-1.jpgImage Enlarger
sikke
55
2015/07/27 - 21:17
Thanks for sharing. Kernel #30 is already in use here.
f0k4l
56
2015/07/28 - 11:46
Oma. How come you don't give a larger parameter option to flash?
KingVeder
57
2015/07/30 - 05:40
Hey I flash it but touch ain't working so using an air remote is there any I can get it back into a mode to flash usin Android tools ? Just goes to twrp now
58
2015/07/30 - 16:32
Did you use the latest kernel #30?
KingVeder
59
2015/07/30 - 17:41
Ye well 90% sure its why I wanted to reflash to be a 100%
60
2015/07/30 - 17:54
You can see the running kernel in settings/About the tab.
71 Guest(s)
Devices in use: Desktop (65), Phone (6)
