[ RK3288 ROM ] Pipo P9 AOSP 5.1.1 custom root firmware (2015/06/03)
KenMic35
Forum Posts: 54
31
2015/07/05 - 17:02
@oma  will you be cooking v1.1 anytime soon?
calestrom
Forum Posts: 30
32
2015/07/05 - 18:58
Humm, finally I flashed the ROM but the digitizer is not working. Managed to flash #51 kernel, but still no go.
edit: attached logs.
If I can help any way, I will volunteer. Have some knowledge of linux & kernels. Been using it since '93
33
2015/07/05 - 22:50
<3>[ 1.217592] vtl_ts 4-0001: vtl ts chip init failed.
The question is what tab is it?
calestrom
Forum Posts: 30
35
2015/07/06 - 06:21
Go back to stock firmware and check the dmesg log.
calestrom
Forum Posts: 30
36
2015/07/06 - 08:02
Went back to RileyROM 1.9, here's the dmesg.
37
2015/07/06 - 17:16
Great, my P9 3G has a VTL touchscreen controller and your P9 3G has a Goodix touchscreen controller. So can't work.
<4>[    0.997200] ___goodix_ts_probe() start____
<6>[    1.147784] input: goodix-ts as /devices/virtual/input/input1
KenMic35
Forum Posts: 54
38
2015/07/06 - 18:18
oma, how much i have to wait for the audio fix pls
39
2015/07/06 - 18:21
As said before this will take longer. Not within the next two weeks.
KenMic35
Forum Posts: 54
40
2015/07/06 - 18:22
ok thanks!
what about gps ,back camera led flash, and front cam
41
2015/07/06 - 18:29
I do have also the tab, so I am myself interested to bring things forward.
As for GPS it does not compile.
Anyhow, here in Germany are sommer holidays now and it is about 38 degrees centigrade in the shade 😉
KenMic35
Forum Posts: 54
42
2015/07/06 - 18:31
i am from malta and today 33 degrees indoors and lots of humidity!
calestrom
Forum Posts: 30
43
2015/07/06 - 19:27
Oh, okay. So it seems that Pipo decided to pick the components for the market. Oh well, let me know if you need anything else.
44
2015/07/12 - 12:09
Here is the latest build v1.1: http://crewrktablets.arctablet.com/?wpfb_dl=2599
And a fix for rear cam flash: http://crewrktablets.arctablet.com/?wpfb_dl=2600
Note: as I am on holiday now it is not tested.
Kernel is still #51, so no progress. However, my tab is on the way to one of our kernel guys. Hope he can dig a bit deeper.
v1.1.pngImage Enlarger
KenMic35
Forum Posts: 54
45
2015/07/12 - 13:05
I will reflash this LP rom once an audio fix is ready
75 Guest(s)
Devices in use: Desktop (69), Phone (6)
