Unfortunately the dtb concept of the 3.10.0 kernel was not fully implemented. So compiling a dtb for a common Pipo kernel is not possible. And the unknown kernel drivers are still the main issue. However, we will see.
Can somebody pls test if this improves the audio quality? http://crewrktablets.arctablet.com/?wpfb_dl=2598
KenMic35Per aspera ad astra, we rock the Tablets !
2013/12/20
Can somebody pls test if this improves the audio quality? http://crewrktablets.arctablet.com/?wpfb_dl=2598- Oma -
I cannot test it as i reflashed riley`s 3.0.1 kitkat rom! grrrr
Thank you so much oma for working on the audio issues on lollipop for the P9
Can you just take the audio files from the kikat rom and inject them in the lollipop rom? maybe audio gets fixed
When it is that easy why do you think we have seen no LP since month?
Thank you for feedback! I am still highly irritated, because audio works fine here on my device.
Can I have a dmesg and a logcat log, pls?
Pls use this tool: http://forum.xda-developers.com/showthread.php?t=1944776
<6>[ 1.098363] Codec driver version RT3261_V1.3.0, in fact you choose rt3224, no dsp!
Ok, seems to be there are different audio chips in the field. Next fake driver. So we need to dig out what is given below 3 levels of fake drivers in the dtb and an unknown driver in the kernel. Unbelievable.
Go back to KK, this will take longer.
2013/12/20
I love lollipop, the tablet runs fine apart from the broken things bad audio, gps, flash and front cam!
ART really makes android fluid and fast!
Also noticed the kernel is set to run the SOC @ 1.8ghz!!
RK3288 ROCKS!!
Almost forgot... can you move the software volume buttons at the bottom to the right?
It is more convenient to have the volume + / - buttons to the right :))
68 Guest(s)
Devices in use: Desktop (63), Phone (5)
