[ RK3288 ROM ] Pipo P9 AOSP 5.1.1 custom root firmware (2015/06/03)
2015/06/11 - 20:43
Gents,
Lollipop has landed on Pipo P9 ;-)
CrewRKTablets AOSP 5.1.1 test build v1.1
- kernel #30 (change kernel and resource in folder rochdev/Image before flash)
- rear cam flash fix (install zip via TWRP)
– stock recovery 5.0.0
– CrewRKTablets homebrew kernel jk #16
– Reboot Menue
outdated:
- CrewRKTablets AOSP 5.1.1 test build v1.0
- kernel jk #30 (improved battery stats, improved sound quality, Bluetooth working)
- kernel jk #51 (improved battery stats, HDMI working)
not working:
- front cam
hints:
Oma's farourite apps for LP (install via apk installer)
Special thanks to Rockchip !
– Oma -
crew.pngImage Enlargerv1.0_4.jpgImage Enlargerv1.0_01a.jpgImage Enlargerv1.0_02.jpgImage Enlargerv1.0_03.jpgImage Enlargerv1.0_09.jpgImage Enlargerv1.0_07a.jpgImage Enlargerv1.0_05b.pngImage Enlargerv1.0_05a.pngImage Enlargerv1.0_3.pngImage Enlargerv1.0_1.jpgImage Enlarger
admin, KenMic35, calestrom, tarjan
kallesone
Forum Posts: 46
Thanks Received: 7
2015/06/11 - 20:50
thanks a lot Oma,i´m going to try it right now,regards.
2015/06/12 - 18:40
Some progress today: http://crewrktablets.arctablet.com/?wpfb_dl=2562
Improved battery stats and audio quality. BT pairing works now.
LP_v1.0_kernel_30.pngImage Enlargerv1.0_09.pngImage Enlargerv1.0_11.pngImage Enlarger
Enr1988, spc48
kallesone
Forum Posts: 46
Thanks Received: 7
2015/06/12 - 22:54
Thanks Oma,i will try it later.
Enr1988
Forum Posts: 34
Thanks Received: 6
2015/06/13 - 09:50
Hope to see this soon also for my P1... anyway thanks for all your work on rk based tablet 🙂
spc48
2015/06/13 - 11:51
Thanks oma for your work... You are the best!!!
2015/06/13 - 21:23
Check it out. Build from post #1 should boot also on Pipo P1. Just change kernel and resource in folder rockdev/Image before flash.
Otherwise you may test this build 😉
Enr1988
Enr1988
Forum Posts: 34
Thanks Received: 6
2015/06/13 - 22:51
Also this build works fine on my Pipo P1, only problem on both build is a little "filckering" of the screen ,visible in the letters...
Edit. on this build when the screen turn off and after a while i press power to turn on display, the display don't turn on and i need to press and hold power for almost 15sec than boot again.
Now check if the p1 build have the same behaviour.. Also attached last_kmsg and dmesg
2015/06/14 - 08:52
The P1 kernel #130 (preempt 6 Mar 2015) was never finished by Pipo. But we can use it as a reference.
Can you pls try again to upload the dmesg log?
valteam
2015/06/18 - 19:50
Hi, did anyone flashed this lollipop for pipo p9 firmware? Is it worth trying it already (kernel 30) ?
I cant wait to get android 5 on pipo p9.
Oma, thank you for your work, keep it up! Make a good final firmware for rk3288, please. I would even donate you some. ))
2015/06/19 - 19:05
Some limited progress, kernel #51: http://crewrktablets.arctablet.com/?wpfb_dl=2573
Improved battery stats and HDMI works now.
v1.0_14.jpgImage Enlargerv1.0_12.jpgImage Enlarger
Enr1988, valteam, spc48, kallesone
KenMic35
Forum Posts: 54
2015/06/29 - 23:00
I flashed this lollipop rom on my P9, the major issue is the sound!!
speakers make strange noises... cracking and popping sounds!
Flashed kernel #30 & #51 same problem!
Oma, can you fix this issue?
I will donate if this custom lollipop rom works fine on the P9!
2015/06/30 - 15:47
We will do our best.
calestrom
Forum Posts: 30
2015/07/01 - 15:41
Will donate too if you get GPS to work. Maybe 3G - too much to ask?
KenMic35
Forum Posts: 54
2015/07/01 - 17:23
Oma will make it work, i am highly confident! Oma makes miracles!
59 Guest(s)
Devices in use: Desktop (53), Phone (6)
