2016/03/14
Dmesg and logcat log please. Here is a tool: http://forum.xda-developers.com/showthread.php?t=1944776- Oma -
Hi Oma!
I bought this tablet as a gift and it's been a nightmare! I had to return it so that they changed the screen, because it got crazy like a ghost was using it. Others have reported this. It's not completely fixed but at least it's somewhat usable now
The biggest issue now is the wifi connection. It fails miserably. I've tried different routers. It keeps getting disconnected every few minutes. I've enabled detailed wifi logs on developer options
I've saved logs with an app called syslog from fdroid, it scrambles the private info. I've attached it to this message. Are they enough? Could you take a look? I will provide more logs. I can't reproduce the issue but it mostly disconnects when streaming a video, youtube, torrent... But also just web browsing
EDIT: Ohhh wow I didn't know we could already use Android 6.0! I read the title and I thought it was only for Pipo P9. So I will try your cm13. Thank you very much Oma!
This sounds also like a hardware issue. Pls make usage of your warranty.
merkelPer aspera ad astra, we rock the Tablets !
2016/03/14
This sounds also like a hardware issue. Pls make usage of your warranty.- Oma -
"Warranty"... I got it on aliexpress, i had to pay ~ 40€ already to send back and forth to fix the screen and wait months.
I'd rather fix it myself. Are you sure this is a hardware issue? I will try cm13 just to try, but I also suspect it may be hardware. I wish I can open and replace any piece myself in that case
No, not sure. I do not have the hardware at hand.
However, it sounds like a loose connection or a bad soldering.
Yes, you can try the CM13 build with the P7 kernel and the P7 model fix.
2016/03/14
No, not sure. I do not have the hardware at hand.However, it sounds like a loose connection or a bad soldering.
Yeah I've seen more people complain about bad soldered wifi antennas on Pipo and other models. So maybe I will try to fix it myself if possible. Thank you very much for your help!
65 Guest(s)
Devices in use: Desktop (54), Phone (11)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
