[ RK3288 ROM ] Pipo P7 LP 5.1.1 custom root firmware (2015/12/02)
2015/12/04 - 18:38
Gents,
This is a LP build for Pipo P7 ;-)
Oma LP 5.1.1 build v1.0
– stock recovery 5.0.0
kernel #65 preempt 21 Sep 2015
– Reboot Menue
not working:
hints:
Oma's favourite apps for LP (install via apk installer)
– Oma -
084.jpgImage EnlargerP7_01.pngImage EnlargerP7_02.jpgImage EnlargerP7_v1.1_03.pngImage Enlarger
seriousmonk
2015/12/05 - 04:52
thank you for the ROM   🙂
but the camera is not working ..
2015/12/05 - 08:30
Pls install this via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2739
seriousmonk
2015/12/05 - 11:46
it works!! thank you very much   😀
shuangwu
2015/12/05 - 15:51
thanks! it works fine and smooth,but xposed(v78 sdk22) doesn't work,I tried several older versions of xposed,still not working.
2015/12/05 - 15:58
Yes, Xposed crashes with all Rockchip LP builds.
paparazzo_1
Forum Posts: 55
Thanks Received: 4
2015/12/05 - 21:27
Hi Oma! Thank you! Note  that "volume up" hardware button cause also "Back" action. Please fix if posible.
pavlikvlasek
2015/12/15 - 07:10
Great work, thanks! But sometimes feel like oversensitive display, was not on 4.4. Any tools or setting to fix this?
2015/12/15 - 16:50
The kernel is looking for the keys. So we cannot do anything.
miox
2015/12/28 - 20:14
Great work, thanks!
What about video problem in this firmware?
Sometimes I can't replay online video after pause.
2016/01/03 - 15:45
Can somebody test this fix for the button issue: http://crewrktablets.arctablet.com/?wpfb_dl=2780
paparazzo_1
Forum Posts: 55
Thanks Received: 4
2016/01/04 - 11:57
Hi, Oma!
Thanks for all fixes and firmware.
But could you fix GPS in this biuld for P7? I tried your "Oma_RK31_P9_LP_GPS fix.zip" for P7, but not helps...
Now the all features works excellent except GPS.
2016/01/04 - 17:19
Try to activate GPS and let me have a dmesg and a logcat log.
To be sure it is not kernel related I asked you a question here: http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/rk3288-rom-pipop9-p4-cm12-1-custom-root-firmware-20151008/page-8/#p55777
paparazzo_1
Forum Posts: 55
Thanks Received: 4
2016/01/05 - 07:54
Hi, Oma!
Here is logcat, I not found the dmesg file.
I tried CM 12.1 from P9 on my P7.
Note that GPS is working with this CM12.1 on my P7.
74 Guest(s)
Devices in use: Desktop (69), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
