[ RK3288 ROM ] Pipo P7 Android 4.4.4 multi-window custom root firmware (2015/01/21)
hades1218
31
2016/05/02 - 20:09
Maybe this helps: https://androidmtk.com/use-rockchip-batch-tool
thanks a lot oma, i'll try this. Works in rockchip 3288?
32
2016/05/02 - 21:21
Yes, but use the flash-tool normally coming with the stock firmware.
hades1218
hades1218
33
2016/05/03 - 00:46
Ok oma but i already download the stock ROM and don't coming with flash tool, i can use the method than before you suggested? ( Rockchip batch tool )
hades1218
34
2016/05/03 - 02:42
Ok oma but i already download this stock ROM: http://chinagadgetsreviews.blogspot.ro/2015/09/download-latest-android-kitkat-444.html  and don't coming with flash tool, i can use the method than before you suggested? ( Rockchip batch tool )
35
2016/05/03 - 17:55
Yes.There are links to the latest Driver Assistant and RKAndroidTool on this page.
You will find them also in our archive:
Driver Assistant - http://crewrktablets.arctablet.com/?wpfb_dl=2766
RKAndroidTool - http://crewrktablets.arctablet.com/?wpfb_dl=1580
kinu
36
2016/12/14 - 19:55
Hi there!
I'm in trouble. Flashed this ROM and now my tablet get stucked in the pipo logo. I've tried to enter recovery but it's gone (like in stock).
I have to say that I have tried previously MM (no exit, but can boot TWRP so can return to loader mode), CM13 (same thing), Lollipop (success!, but I want to use xposed).....but now no recovery, so...
I've tried to enter loader mode by using
  • power and volume+ =  recovery
  • power and volume- = boot normal and stucks
  • reset and power = nothing, no boot
  • reset and volume - =nothing,no boot
  • reset and volume + =nothing, no boot
So, how to enter loader mode in the P7????  Help me, please 🙁
EDIT: shame on me. It was the easiest way. Just hold volume+ and connect the cable
JEssicannn
Forum Posts: 252
37
2019/10/23 - 02:04
148 Guest(s)
Devices in use: Desktop (136), Phone (12)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
